Go Back   The RadioReference.com Forums > Commercial and Professional Radio > LTR Trunking
LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems
Old 04-11-2007, 01:24 PM
Default LTR Trunker?
Hi guys;
I'm going to be needing to monitor an LTR system in the semi-near future. I don't have any system details as of yet, except that it's UHF.
What are my options for a Trunker-like program? I've only ever used the LTR-trunker program, but wasn't too impressed.
Old 04-11-2007, 02:14 PM
DaveNF2G's Avatar
LTRTrunker is the only software (AFAIK) that will track all flavors of LTR trunking. I'm not sure what would be unimpressive about that. :-)
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 04-11-2007, 06:16 PM
Send a message via Yahoo to N0JRD
Will the LTR Trunker work on LTR Passport systems?
Old 04-11-2007, 06:25 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Yes, along with Multi-Net also.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 04-11-2007, 11:18 PM
The fact that LTRTrunker (as well as regular Trunker) just plain suck when it comes to error correction and filtering out bogus decoded data.
Old 04-12-2007, 06:32 AM
rescue161's Avatar
I'm running LTR Trunk here with no problems. Maybe it's your data slicer that is the problem? I've never used regular Trunker because T4Win and UniTrunker have always worked very nice for me. I wish Rick would implement LTR into the next UniTrunker release! ~hint~ ~hint~
Scott
KE4FHH
Hams Against Magnetic Mounts
Religion - Kills folks DEAD!
Old 04-12-2007, 10:54 AM
DaveNF2G's Avatar
Well, your original posting asked for options. That has been answered - your only option is LTRTrunker. Continuing to complain about its performance will not create any additional software choices.
If I were a moderator, I would say that this thread has run its course and lock it.
Old 04-12-2007, 03:16 PM
So sorry it is not to your liking...let's see...that leaves you
*zero* alternatives.
Eric not only adapted Trunker to LTR, he came up with a filtered
data slicer circuit. Regular slicers can give lots of false decodes,
but you'll notice I'm not complaining that I get them because I haven't
built one yet.
LTR frames do have a checksum but I can't say if LTRTrunk uses
it to drop bad frames, probably not. If not, someone could modify the
program to do so.
The best you can do without receiver remote control is scan
the channels conventionally with delay off, and build up a list
of Group IDs (if that's what you're looking for).
With all those "M" radios, you can't afford a cheap LTR scanner, or
perhaps a "real" LTR radio e.g. HT1250LS or whatever?
I tend to agree with DaveNF2G, not much left to say in this
thread.
Dave
Old 04-12-2007, 10:05 PM
I never said I didn't have a /\/\ radio that can do LTR. I have several. But that isn't going to help me track a system. There's a new UHF LTR system in town here that nobody knows about (it's not even licensed on TAFL), and I'd like to see what I can do about mapping it out.
LTRTrunker is "okay", but but it's lacking a lot of things that would make it better, IMHO. A program like Treport for LTR would just plain kick ass. Also, LTRTrunker was never intended to be a stand-alone release, it even states in it's help text that it's a proof of concept program, and will be expanded/worked on. From what I hear, there's another LTR decoding program in the works that will leave Trunker in the dust. We shall see what happens.
Old 04-13-2007, 08:29 PM
program to do so.
Is the source code available? If it is, I'll add the checksum handling. If someone posts a URL, I'll take care of it.
I tend to agree with DaveNF2G, not much left to say in this thread.
By all means, lock away. Jeez.
BTW Mike, I have an SB16-based LTR analyser we can point at that system. It uses the checksums to avoid false decodes.
Old 04-13-2007, 09:02 PM
Seņor Member
So ... you don't have the checksums?
So you DO have the checksums?
Sorry, I'm just easily confused.
Eric magnanimously posted the checksums for LTR and Passport a few years ago (just before the switch from trunkedradio.net to radioreference.com). Holler if you have trouble finding them.
For the record, I'm certain that Eric's code employs checksum validation of incoming frames (IIRC, LTRDump had the option of dumping all fragments - not just "good" frames). Beware, the LTR checksum is only 7 bits (but you knew that). It isn't as strong as BCH or Reed Solomon and provides zero error correcting capabilities.
-rick
Old 04-13-2007, 09:41 PM
So I see!
No, I don't need them. I worked out the PassPort checksums back in 2002; LTR is quite similar, so it just took a bit of inspection of the output from a local system to figure it out.
In that case, I withdraw my offer.
Both LTR and PassPort use 7 bit checksums (with PassPort adding a parity bit, IIRC) and as you say, no FEC.
Old 04-13-2007, 10:19 PM
Seņor Member
So I see!
That's great. No doubt in the last five years you've made improvements.
I'd like to point out something that Mike was quick to overlook. Eric was able to figure these out and publish his results for all to see and release a working program as proof of this discovery. He deserves credit for these contributions to the hobby - something the folks responding to exkalibur's original question seem to understand. Specifically in the area of LTR, I can think of only one other example (from "opus"). Since 2002, those are the choices we've had ... for which I am grateful.
Make no mistake - I appreciate your contributions too. Might you be releasing a new LTR decoder? If so, I look forward to seeing an official announcement.
-rick
Old 04-13-2007, 11:14 PM
At the time, I had been working with Trident Microsystems and Motorola, investigating some of the deficiencies that existed at that point (mainly in the LS+ firmware). IMO, it wouldn't have been proper to release anything to the public, even though it had been developed on my own time and through reverse engineering, given the professional relationships in place.
And no, I haven't made any improvements in my PassPort decoder over the years, as it did what I needed it to do and I don't require it / use it any more and the local PassPort systems are gone now anyway.
I have no problem releasing an LTR decoder, but how much interest is there in a DOS-based SoundBlaster-driven decoder?
Old 04-13-2007, 11:40 PM
Seņor Member
I think the big hurdle for most folks wanting to use LTR trunk is the requirement of a filtered data slicer. The demand is definitely there. I'd say ... "Go for it!" (plus Windows and Linux versions too ).
-rick
Old 04-14-2007, 08:13 AM
DaveNF2G's Avatar
I agree. One of my radio computers can't run any version of Windows later than 95, so I run DOS programs on it. Right now I have one slicer for Motorola and EDACS, a 4-level for more complex protocols, and a special LTR slicer. Instead of swapping slicers and cabling around while experimenting, I'd much rather use the soundcard.
Old 04-14-2007, 09:05 AM
cg cg is offline
I'd definately be interested in the LTR/Passport decoder. Public safety LTR and Passport as well as many commercial systems exist around me. Another tool in the drawer.
Thanks in advance.
chris
Old 04-16-2007, 04:21 PM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
to use LTR trunker will I have to have a LTR Data Dicer or will my Discriminator tap work on my pro 95?
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Old 04-16-2007, 05:06 PM
DaveNF2G's Avatar
That's like asking whether you should walk to school or carry your lunch.
Yes, the discriminator tap will work, provided you have the appropriate data slicer for the type of signals you wish to decode.
Old 04-16-2007, 05:11 PM
Saint's Avatar
Default Re-Slicer
Thanks in advance.
chris
I also would like to be able to use one of the decoders for LTR Systems, I have 12 LTR Standard Systems I listen too and I don't have a filtered data slicer for the decoder programs.
Steve
Similar Threads
Helpful Trick: LTR Passport and PRO-96 KD4YGG LTR Trunking 7 12-30-2006 01:07 PM
Total Communications LTR in Pensacola, FL DanHenry Florida Radio Discussion Forum 0 11-19-2006 10:16 PM
Trunker Glitch jrbobdobbs Trunking Control Channel Decoding 6 09-20-2005 03:51 PM
Trunker help needed laser21012 Trunking Control Channel Decoding 19 09-20-2004 07:05 PM
Trunker, Windows XP, and Optocom - I'm Stumped KD4YGG Trunking Control Channel Decoding 7 08-04-2004 11:48 AM
