Originally Posted by cubn
Sounds like LTR Passport to me.
That doesn't means that it's Passport, all LTR systems make that noise. See this part in the wiki:
Typically on LTR systems, each of these controllers periodically sends out a data burst (approximately every 10 seconds on LTR Standard systems) so that the subscriber units know that the system is there. The idle data burst can be turned off if desired by the system operator. Some systems will broadcast idle data bursts only on channels used as home channels and not on those used for "overflow" conversations. To a scanner user the idle data burst will sound like a short blip of static like someone keyed up and unkeyed a radio within about 1/2 second. This data burst is not sent at the same time by all the channels but happen randomly throughout all the system channels.
