Thus the advantage of GRE scanners on LTR.... With the exception of the upcomming PRO-2051, and 97,.... You only need to make sure that the chans are set to LTR mode..... and can list the freqs in any order as long as you list them all. If you can get ahold of a PRO-92, or 2067, use those to listen and using the trick that I found and listed on another post, monitor and find the LCN's.... then you should not only be able to get additional TG ID's, but also the complete LCN's for the Cell your trying to hear. As for the Uniden.. I am not extremely familiar with how they should completely be set up for LTR.. is there a place to set the chans to LTR? (If yes, be sure you did that) Is there a place to set the bank to LTR? (Possibly that will help if so)
Be sure to check out all the threads in the LTR Discussion as there are several good tips on tracking these effectively and accurately... And a few good tips on getting proper LCN's!
The only other suggestion I have is see on the FCC pages if they have OFFLINED this system for any reason, and look for any conventional freqs for SLEMCO that might be in use in this scenario.
