Originally Posted by Earp
I have all the LCN numbers, my issue is there is several LCN's on each frequency with only 3 frequencies.
Please read
http://wiki.radioreference.com/index.php/LTR There is only one LCN/Frequnecy. The other TGID's are GOTO or "Guest" users on a freq. They were sent from their home LCN to another because their home LCN was busy.
You might also find this useful:
Step-by-Step LTR Programming Guide
http://myweb.cableone.net/marksscann...unking_systems
http://myweb.cableone.net/marksscann...talk_group_ids
Note: all of these suggestions are based on having the correct frequencies in the right channel order of the bank they are in.
0-13-110 R13 This would be example of user on home LCN 13
0-08-156 R17 This is probably a guest who's home LCN is 08 on LCN 17
Also, you are getting errors (quite common) in your LCN
Can only be LCN nbrs as high as 20
0-29-078 R21
1-17-082 R22
1-17-106 R22
1-02-053 R24
Typically, systems area codes are either 0 or 1. Your system looks like 0
856.4625 (frequency)
1-11-187 R03 This one probably is an error also.
