Go Back   The RadioReference.com Forums > Commercial and Professional Radio > LTR Trunking
LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems
Old 01-14-2008, 05:02 PM
mikebennett's Avatar
Default LTR Passport Question
Can LTR Passport transmissions be monitored if you enter the system frequencies in conventional mode?
Old 01-14-2008, 05:26 PM
inigo88's Avatar
California DB Admin
Yes, they just may not make sense... since Passport is a form of trunking you may hear multiple different conversations on different talkgroups back to back on the same frequency, and you'll have no way of telling them apart other than by ear. Also Passport frequencies usually send out an idle burst every 3-5 seconds that sounds like a click as the repeater keys up with dead air, and this can get pretty annoying.
I recommend programming all the frequencies for the site you want to listen to with delay turned OFF (so it won't get stuck on a frequency's idle burst). Then if you're trying to follow a conversation that left the channel, just keep scanning to find it again.
Old 01-14-2008, 05:49 PM
Thanks for the info. I pass through one city that has this system but I'm not there long enough to ever hearing anything other than the annoying clicks.
Old 01-17-2008, 05:55 PM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
Speak of that 3 to 5 second click. Do you know what the difference with the one that does it every 3 to 5 seconds and the one that does it about once every second?
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Old 01-17-2008, 06:18 PM
Saint's Avatar
Default every second
I also get several frequencies in the 460. mhz band that I get the keyup every second, drives me crazy.
Steve
BC396T Scanner
Pro-2045 Scanner Discriminator Tap
ARC396TPRO Software
Old 01-18-2008, 11:09 PM
Channels that pulse slowly are either misconfigured, or are not collect channels, or are not PassPort channels.
Collect channels should always be programmed to pulse every second; if they aren't, subscriber radios will take forever to roam from site to site; do the math - [neighbour list with five neighbour sites] x [monitor each neighbour frequency for at least 5 seconds to pick up an idle burst] = you gotta be joking.
Home channels can pulse at a slower rate, since a slow pulse rate would only cause a slight delay in registering for homed radios when they get powered up.
Similar Threads
Tow trucks yukon San Francisco Bay Area Discussion 37 11-11-2009 08:51 PM
Marion IL PD LTR Question stooley Illinois Radio Discussion Forum 3 12-27-2006 09:04 AM
BCD996T LTR Question RONALDPURDUE Uniden Scanners 1 12-19-2006 10:05 PM
LTR observation and question about system programming edweirdFL LTR Trunking 7 11-18-2006 10:32 AM
Question about LTR? klown General Scanning Forum 7 09-26-2006 05:05 PM
