Go Back   The RadioReference.com Forums > Commercial and Professional Radio > LTR Trunking
LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems
Old 03-04-2008, 05:52 PM
ATF1224's Avatar
Send a message via AIM to ATF1224 Send a message via MSN to ATF1224 Send a message via Yahoo to ATF1224
Default Standard GX4800UT LTR Radio
Does anyone have any experience with these?
I am trying to program one and when I try to read the radio I get "Password read error" and when I try to write to them I get a "F Chart Read Error".
I am running the software in DOS (4800dual.exe Version 2.0 1998). It says to hold down the phone button while powering the radio on, but that puts it in the test mode and I still get the errors. I was able to successfully read one radio (I don't know what I did different...) and then one time while I turned the radio on while powering it up I got a blank screen and was able to write to the radio, but it gave me an error and now the radio just shows blocks on the screen.
What trick is there to programming these?
Jake
Old 03-06-2008, 09:33 AM
Texas DB Admin
The GX4800 is actually a pretty good radio. Big problem we found is that there were so many versions that had a different software version for each. The software you have should work on the AC version. We have a had a few AA versions come through here that we bricked because we didn't check first and use the older software. You can find the version on the tag on the back of the radio.
They are kind of a nightmare sometimes to get set up, but once they are programmed up, they operate very well.
Old 03-06-2008, 07:53 PM
ATF1224's Avatar
Mine are all AC versions...
Jake
Old 03-07-2008, 09:04 AM
Texas DB Admin
You might also want to make sure you are using an older computer, and in a pure DOS mode if possible (not a MS-DOS window)
Old 03-07-2008, 09:20 AM
ATF1224's Avatar
Done and Done.. I can't figure this one out....
Jake
Similar Threads
My Pro-2055 and My Local Radio Shack TCRailPhotog Radio Shack Scanners 15 11-22-2007 01:45 AM
EUP agencies to share in new police radio gear Firetxmi Michigan Radio Discussion Forum 1 03-16-2007 04:38 PM
national sos network in connecticut wesct Connecticut Radio Discussion Forum 5 12-01-2006 02:20 PM
How did you get interested in radio? Exsmokey General Scanning Forum 24 11-29-2005 08:47 PM
