Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maine Radio Discussion Forum
Maine Radio Discussion Forum Forum for discussing Radio Information in the State of Maine.
  #21 (permalink)
Old 07-28-2012, 1:32 PM
GothamCity's Avatar
hey guys I put up a feed for Portland, South Portland, Scarboro, and USCG Ch.16. Let me know what you guys want to change or add. Scanner location is near the jetport
  #22 (permalink)
Old 07-30-2012, 7:20 PM
Adenosine's Avatar
Seems to have alot of hum, wondering if the desktop input vol is turned up and the radio vol is set low or is the other way around that does that? Just might want to check your input audio lvls. Tough to listen too.
BC780XLT, Pro-2026, BC855XLT
MaineBoxAlarm on Twitter
  #23 (permalink)
Old 07-30-2012, 8:04 PM
N1BHH's Avatar
Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
Hum equals ground loop. The scanner output is high also, but not the cause of the hum. What is needed is a ground loop isolator. They can be made from an audio transformer and placed in line or can be purchased from Radio Shack. Hum can be fixed easily.
Ground Loop Isolator - RadioShack.com
The ones that I use are here:
ISOLATOR Isolates grounds between Radio and Sound Card. Reduces or eliminates ground-loop hum and noise. ISOL8R For the Sound Card LINE OUT to reduce Transmit audio Noise and HUM [ISOLATOR] - $12.95 : BUXCOMM , Where Ham Radio Operators Come to Shop
WQLF416 = GMRS
Pro's 94, 106, 164, 197 (2), 2006, 2015, 2021, 2055
  #24 (permalink)
Old 07-30-2012, 8:59 PM
GothamCity's Avatar
I'll play with the settings tomorrow when I get off duty. I noticed the hum as well, might go buy that isolator
  #25 (permalink)
Old 07-31-2012, 8:13 AM
Default Portland feed
Is there a feed just for the Portland police?
  #26 (permalink)
Old 08-01-2012, 7:36 PM
GothamCity's Avatar
As of right now its mixed in with FD. Unless more people would like a PD feed.
  #27 (permalink)
Old 08-01-2012, 9:25 PM
I have plans to make a Portland and South Portland PD feed at somepoint. But it wont be until the end of the year.
  #28 (permalink)
Old 08-13-2012, 5:23 AM
GothamCity's Avatar
Talking
Its great to see everyone using the Portland feeds! I switched up the scanner a tad and got rid of USCG channnel and replaced it with Westbrook.
Thanks for listening, it's always nice to see the max listener number go up. And it justifies that people want the feed.
  #29 (permalink)
Old 08-18-2012, 8:32 AM
SOCCERCOACH's Avatar
Default Portland Scanner
Hello any chance of tagging the BCT15, its not easy for us who are not from the area to id who is talking or what City is dispatching>??? Thank you again for providing these scanners
Soccercoach
  #30 (permalink)
Old 08-24-2012, 6:38 AM
I am not sure which feed you are specifically talking about, however I can tell you that the "Portland and South Portland Fire and EMS" does have tags enabled. If you are talking about the other Portland feed, I believe he is using a BCT8, which correct me if I am wrong is not alphanumeric.
