Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maine Radio Discussion Forum
Maine Radio Discussion Forum Forum for discussing Radio Information in the State of Maine.
Old 02-27-2013, 12:45 PM
Default State Police Region 2
Has anyone thought of broadcasting State Police Region 2? I would love to be able to listen to it. Thanks for making the effort at broadcasting what you already do.
Old 02-28-2013, 10:20 PM
lost_in_maine's Avatar
Welcome..as I see its your first post..I used to stream it, along with others..been awhile since I done it, and now with the Homepatrol want to start up again, However I have not seen any clear-cut FAQ's or links searching here or with Google on how to do it with a HP, and be able to display the tags.Until that happens, It won't be for awhile..
HP-1 Extreme
BCD-396XT - BCD-396T - PRO-96 - BC9000XLT
ScanTenna - Diamond - Discone-Grove - Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
Old 03-01-2013, 6:34 AM
Thanks for the reply. I hope you can figure out how to stream your feeds.
Old 03-02-2013, 8:14 AM
RonnieUSA's Avatar
There is support for text tagging on the HP1, have a look at this >> What's New
ProScan
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 03-02-2013, 9:02 AM
ProScan's Avatar
ProScan
RonnieUSA, Thanks for pointing that out. HomePatrol Extreme upgrade is required for the HomePatrol serial communications to communicate with RadioFeed.
ProScan - Taking Computer Aided Scanning To The Next Level!
http://www.proscan.org
bob@proscan.org
Old 03-02-2013, 9:24 AM
RonnieUSA's Avatar
Your Welcome, if his signature is right He would be able to do it.
Plus I use RadioFeed for my feed, very happy with it.
Old 03-02-2013, 2:35 PM
I played a bit with radiofeed a bit, and was able to see the metadata in the program, but was first trying to set it up locally across the home network, before trying to go live..I can't figure out the next steps..as far as the network path. I was going to use a dedicated site to stream too, instead of here on RR..
HP-1 Extreme
Old 03-02-2013, 2:48 PM
RonnieUSA's Avatar
If You ask in this forum, I'm sure You would get the help You need. >> Streaming / Broadcasting / Audio Recording - The RadioReference.com Forums
The developer of RadioFeed post there, and helps all the time.
Old 03-04-2013, 12:48 PM
Thanks for the replies. Great support!
Tags
maine state police region
