Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maine Radio Discussion Forum
Maine Radio Discussion Forum - Forum for discussing Radio Information in the State of Maine.
  #21 (permalink)
Old 02-28-2017, 1:01 PM
Was MaineRadioMan
im not even hearing the control channels so im thinking its probably not as powerful as say Auburn/Lewiston or NH SP
Up on a huge hill with a tower 100ft in the air!
2- BCD996P2
2- BCT15XT
  #22 (permalink)
Old 02-28-2017, 1:02 PM
You also have to keep in mind that it's 800mhz which doesn't the range that vhf does so comparing it to the twin cites or NH isn't fair.
  #23 (permalink)
Old 02-28-2017, 1:04 PM
Was MaineRadioMan
True but the CMP system is well rigged and receives super well
2- BCD996P2
2- BCT15XT
  #24 (permalink)
Old 02-28-2017, 1:06 PM
Default Portland p25
True. I do know part of the upgrade was adding new towers but I dont know if that's happened yet
  #25 (permalink)
Old 02-28-2017, 1:08 PM
Was MaineRadioMan
very nice
2- BCD996P2
2- BCT15XT
  #26 (permalink)
Old 02-28-2017, 3:11 PM
Was MaineRadioMan
I'm in Lewiston now and I don't hear any CC channels or nothing.
2- BCD996P2
2- BCT15XT
  #27 (permalink)
Old 02-28-2017, 3:14 PM
That doesn't surprise me much. The motorola system anyway drops off quickly after 25-30 miles outside of portland. I dont know if the p25 system will have more range or not
  #28 (permalink)
Old 02-28-2017, 3:16 PM
Was MaineRadioMan
Should have no problems hearing it in L/A. Analog why's as far as p25 thats what I'm reporting
Sent from my SM-G930V using Tapatalk
2- BCD996P2
2- BCT15XT
  #29 (permalink)
Old 02-28-2017, 3:28 PM
K1IWN's Avatar
That doesn't surprise me much. The motorola system anyway drops off quickly after 25-30 miles outside of portland. I dont know if the p25 system will have more range or not.
That sounds about right. I am in Poland and can pick up Portland dispatch on the mobile as I head out my door. I can pick up portables around the Gray/Cumberland line.
The P25 system MSComm uses has towers all around, as does CMP. The 30 mile circumference area is about right on those as well.
If they have a tower somewhere in North Deering, I have a shot of getting it at the house on the base. I am right on the 30 mile doorstep.
- Mike
SKYWARN CCRadio-SW BCD436HP ProVoice + DMR GPS BCD536HP ProVoice + DMR ARC536 HomePatrol2 Extreme
  #30 (permalink)
Old 02-28-2017, 9:37 PM
If you look at the gps info for mscommnet on RR the have the range set to 25 mi but that's very conservative for vhf. I pick up towers up to 50 mi with a bcd436hp and 40 inch telescopic antenna. 800 mhz just doesn't have the range of vhf. If it's any consolation the vhf simulcast of Portland prime and south Portland prime isn't going anywhere so you'll certainly be able to listen to that.
  #31 (permalink)
Old 03-01-2017, 1:02 PM
K1IWN's Avatar
Right on!
I know I can pick up Portland on VHF on the 436 in my car in my driveway. I have not added the system on the 536 as of yet since I upgraded my base antenna. I will do that and see what I can pick up.
I am thinking it will be a remote chance of picking up the Portland 800 mHz transmissions where I am. If I was on top of a hill I'd have a better shot, but I am not (halfway up with some obstruction to the S/SE. I'll play around and see what I can get. I am not ruling out running an outdoor wire, but I am skeptical of too much of a financial investment chasing a pipe dream.
I get my Portland fix for action since I work there, so I am by no means shut out. It would be nice to get it at home, but the 536 is pretty busy with all that I monitor there. It would simply be the cherry on the sundae.
- Mike
  #32 (permalink)
Old 03-01-2017, 1:15 PM
Right on!
I run a 536 in the car but in order not to miss too much I run a 436 and 396 in tandem when I'm home. Most of the time you wouldn't miss much not hearing the 800mhz side anyway.
  #33 (permalink)
Old 03-01-2017, 5:56 PM
A long range Yagi should help if you can git it up some. When I was in Lyman a few years ago I could just hear the control channel on a rubber antenna in the 2nd floor. Anything is possible.
  #34 (permalink)
Old 03-01-2017, 5:57 PM
Scanning is a weird and ever surprising hobby!
  #35 (permalink)
Old 03-01-2017, 5:59 PM
Was MaineRadioMan
I might be relocating closer to Portland area or Scarborough so then I won't have any issues
2- BCD996P2
2- BCT15XT
  #36 (permalink)
Old 03-02-2017, 3:33 PM
K1IWN's Avatar
Which one would you recommend, Bill?
- Mike
  #37 (permalink)
Old 03-03-2017, 6:03 PM
Looks like Portland has postpone the changeover until July .
  #38 (permalink)
Old 03-03-2017, 8:43 PM
I just set my 436 on portland metro p25 for an hour or so without a peep. It locks on a CC but that's it. I'll check periodically over the next 2 weeks while I'm home for spring break but I wouldn't say there will be much to hear for a little while.
  #39 (permalink)
Old 03-03-2017, 8:44 PM
Just out of curiosity where did you see this?
  #40 (permalink)
Old 03-03-2017, 9:00 PM
I use to dispatch and I have a friend who still works for an agency who is involved.
