Go Back   The RadioReference.com Forums > Topic Specific Forums > Marine Monitoring Forum
Marine Monitoring Forum This is the place to discuss monitoring marine communications
Old 04-06-2008, 01:15 PM
Default rescue 21 USCG
I went to the local station/sector the other day and got to se this in action, it is AMAZING!!
http://www.uscg.mil/rescue21/projectdescription.asp
SO now when there is a distress call and the CG looses contact, they can still find their last nown position, unless they have an EPIRB of corse.
bc350c
(and hopefully a bcd396t for xmas!)
Old 04-06-2008, 01:17 PM
http://www.gdc4s.com/content/detail....f-430e9f7972fa
bc350c
Old 04-08-2008, 12:38 AM
icom1020's Avatar
Thought it was interesting how incidents like this may have showed just how lacking the CG is in technology like recorders.
http://www.boatus.com/seaworthy/swdew.asp
Equipment. The Safety Board concluded that the tape recorder may have contributed to the Coast Guard's lack of response. Investigators found that the tape recorder being used by Coast Guard Group Charleston (and other stations) is difficult to operate when searching for a specific message. The report notes that the Canadian Coast Guard uses a model recorder that allows a watchstander to easily press a button to play back the most recent message. "The emphasis," the Safety Board says, "should be on 'easily' because the easier the task, the more likely it will be performed."
Had the 0217 message been replayed by the watchstander, at a minimum, the report notes he could have broadcast an urgent marine information broadcast that would have alerted other mariners of the distress call. It is also likely, the report says, that the watch duty officer would have responded much differently to the 0628 call from Pearl Ace, had he been aware of the 0217 call.
What the Coast Guard watchstander wouldn't have been able to do was ascertain where the mayday call was coming from. According to the Safety Board's report, Coast Guard Group Charleston's direction finder (DF) has limited range and is "inaccurate, unreliable, and obsolete." Tests of the equipment found bearing errors of as much as 101°. (Charleston's DF can only give a line-of-sight bearing and cannot give a fix of the vessel's position.) Investigators found, not surprisingly, that watchstander records indicate that the Charleston's DF is usually turned off.
Similar Threads
Sticky Thread for MilAir III TinEar Maryland Radio Discussion Forum 5266 01-20-2009 02:02 PM
South BALDWIN,AL Attackron Alabama Radio Discussion Forum 2 01-15-2008 07:00 PM
USCG Baltimore doctordave Maryland Radio Discussion Forum 6 10-04-2007 05:45 PM
Montgomery County Fire-Rescue apparatus/station list? dc2wheel Maryland Radio Discussion Forum 12 03-16-2007 05:28 PM
United States Coast Guard Frequencies enginecompany General Scanning Forum 7 12-26-2005 11:29 AM
