Go Back   The RadioReference.com Forums > Topic Specific Forums > Marine Monitoring Forum
Marine Monitoring Forum This is the place to discuss monitoring marine communications
Old 08-20-2008, 08:06 PM
Default Marine Antenna
I have a offshore fishing boat. It came equipped w/ two (2) marine vhf radio antennas. We are only using one of those. We would like to connect our am/fm marine radio to the extra antenna. What type of conversion needs to take place. I have found a band splitter/separator. We do not need to split the signal, just convert. What are your suggestions?
Old 08-21-2008, 01:25 AM
What kind of radio do you mean by an "am/fm marine radio"? Never heard of such a thing.
Regards,
Jack
Old 08-21-2008, 03:10 AM
I think he might mean an AM/FM radio designed for marine use, as is to be mounted on a water going vessel of some sort.
If you still have the coax attached to the unused antenna, then an adapter should work if you can find one that fits. Most likely the antenna coax would have a PL259 connector, so an adapter to adapt that to whatever your AM/FM radio uses. I guess those use the old "motorola" connector.
I think SO-239 to Motorola male would be what you would be looking for, but since I do not know what radio you have (and if they have a special connector) then I cannot be 100% sure.
edit....
The AD259 on this page looks like it would be the one. I have not seen the back of any sort of AM/FM radio to know how deep the jack is, as to whether this will go deep enough to work right. I would guess so.
http://radioproshop.com/connectors-rf/connectors-rf.htm
I have never used that place before, just linking what I found with a picture and cheap prices
Old 08-21-2008, 05:11 AM
I would not expect great things from that antenna on the AM broadcast band, but it is worth a shot.
Some posts can be interpreted in various ways.
Mine generally mean exactly what they say.
Tags
antenna, boat, marine, vhf, watercraft
Similar Threads
Antenna Rant. questions answered... yaesumofo Uniden Scanners 7 06-30-2009 11:23 PM
Marine Antenna TD Antennas and Coax Forum 1 03-16-2008 02:54 AM
PCTEL Antenna Specialists MONR33 kf4lne Antennas and Coax Forum 15 08-30-2007 09:17 AM
Indoor Attic Antenna for High Def Dish Network tuner cousinvinny Antennas and Coax Forum 5 07-08-2007 02:16 AM
RS 800Mhz antenna on RS Pro95 handheld radunn Antennas and Coax Forum 27 09-23-2004 10:44 AM
