Go Back   The RadioReference.com Forums > Topic Specific Forums > Marine Monitoring Forum
Marine Monitoring Forum This is the place to discuss monitoring marine communications
Old 10-14-2009, 10:35 PM
Default Marine raido great lakes
Hi, I would like to know why in the great lakes area particularly on Lake Michigan why when listing to marine CH 23 A I hear the Coast Guard, but only one side of the conservation, it it encryption, or am I just out of range? Also dose the CPD marine unit, Conversation Police and Lake county Sheriff marine unit ever come up on the marine radio? I have not hear them come up once on them. Please let me know thank you.
Old 10-15-2009, 02:54 AM
DPD1's Avatar
You're most likely just out of range from the other party. Just about anybody on the water should be on VHF at some point. You probably just haven't found the freq they use. If you can do UHF air, you might get some CG stuff on that.
Dave
www.DPDProductions.com
Antennas & Accessories for the RF Professional & Radio Hobbyist
Old 10-15-2009, 09:04 AM
The police marine div (at least in my location) use marine radios to talk to other boaters .If its police related they will use police radio's like they do on the road .So check county or city police freqs .Police marine unit's will go by PB 1 PB 2 or the like .see if that helps
Old 10-15-2009, 09:54 AM
FLRAILMAN's Avatar
Default Marine radio/Great Lakes
All the information you seek is in the RR database for Chicago City, the police operate on a number of vhf marine channels. Also check the RR WIKI under miltary & the new U.S.C.G uhf aviation frequencies are listed therin. When you say you are hearing one side of the conversation on vhf marine channel 23A, is it the coast station? If that's the case the watercraft are probably out of your scanners receiving range, watercraft transceivers are only 25 watts & they can switch to only 1 watt for low power applications & the portables output varies from 1 to 6 watts depending on the needs of the user. Also watercraft are at sea level which is the lowest transmitting point anywhere. You have be in very close proximity to the shore to recieve units operating at such low power. Maybe you need to look into an outside antenna application for increased reception range, if you have additional questions, feel free to ask & someone will gladly assist you. Good luck.
FLRAILMAN
Old 10-15-2009, 07:50 PM
Default One sided conversation
When I read this, the thought crossed my mind that I have read or heard somewhere that the Coast Guard sometimes operates duplex to each other. What I mean, they are talking and listening on two different freqs.
Old 10-16-2009, 04:45 PM
Channel 23A is simplex. All channels with an A are USA channels. All CG working channels in the VHF-FM marine band are simplex. Most likely you are just out of range of the vessels. You have remember that the CG uses very high towers and would cover a large area. The vessels are limited in their antenna height and if you want to receive them will have increase or update the antenna on your end.
Hope that helps you out.
KB3QWC
Old 10-16-2009, 05:09 PM
Wirelessly posted (BlackBerry8310/4.5.0.110 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/-1 UP.Link/6.3.1.20.0)
Lake Co Sheriff and Chicago PD use their own frequencies. They only use the marine radio to talk to boaters or USCG
Old 10-19-2009, 08:12 AM
The Chicago PD M units also use channel 6 quite a bit as well when talking amongst themselves.
Old 10-26-2009, 11:31 PM
During Maritime information brodcasts I noticed that the watchstander always ends sirten transmitions with "break?" What dose this mean please let me know thank you.
Old 10-29-2009, 09:03 PM
BREAK: Indicates the separation of the text from other portions of the message.
KB3QWC
Old 10-30-2009, 04:20 PM
ecps92's Avatar
Send a message via AIM to ecps92 Send a message via Yahoo to ecps92
"Let me pause and catch my breath"
a pause to indicate the traffic related to that "incident" or "rule/regulation" or "portion of the broadcast" has ended. We now move onto the next peice of radio traffic
Bill Dunn N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Feeding USCG Sector Boston at
http://www.scannewengland.net/index....geid=nesflogon
