Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum - Forum for discussing Radio Information in the State of Maryland.
Old 05-09-2008, 7:43 PM
Default Cecil County Fire/EMS
Can anybody advise what the frequencies are for Cecil County Fire/EMS ops? I've found some references here but nothing that specifically says "ops".
Old 05-09-2008, 8:14 PM
bwhite's Avatar
Wink
They're not in the database? http://www.radioreference.com/apps/db/?ctid=1195
I don't know Cecil but the above link should take you close to what you want if it's there. Good Luck.
Old 05-09-2008, 8:22 PM
Wiki Admin Emeritus
Nope, they're not - and the Cecil system is not monitorable, so if they're using the TRS there, you're SOL...
For EMRC, according to this page (which is rather dated, and likely needs a major update)...
http://www.radioreference.com/apps/db/?aid=1636
Cecil is region 3, so it uses Med4 and 8, Tone C
73 Mike
Old 05-09-2008, 8:57 PM
DELCOLHFC's Avatar
David, The best you are going to be able to do is monitor the 155.5275 'patch' provided by the County. I can usually catch it up here in Delco PA with a decent outside antenna. I know this isn't the hoped for answer but it's better than nothing.
Tom
I keep a scanner on just to hear what my wife THINKS they just said.
"Police are putting CHOP STICKS in the road?" Gotta love her!
Tri-State live feed http://delaware.pa.scanamerica.us/index.php
Old 05-09-2008, 10:33 PM
Thanks Mike,
I'm a little confused with your reply tho... "the Cecil system is not monitorable, so if they're using the TRS there, you're SOL..." I'm using a BCD996T here in Newark, DE. and their 154, 155 MHz freqs, aside from dispatch on 155.5275 and what is stated as the "helo patch (possibly Ops 6?)", are only squelch breaks and (was that a data burst I just heard?) for me.
Old 05-10-2008, 12:47 AM
They are using a M/A Com pro voice TRS. No scanner currently on the market can scan a pro voice system. You can monitor dispatch only with a scanner on 155.5275 as others have said. You are not going to hear anything by scanning the TRS frequencies.
If you stay near the computer you can listen to the fire/ems ops channels on teamspeak. Just go to www.incidentbroadcast.com and download and install the teamspeak software. That is the only way currently to monitor the ops channels.
KE3ON/
Uniden BCD536HP(2)/GRE PSR-800/Uniden BCD996T/RS Pro-2006/Regency R1040/
Old 05-10-2008, 5:58 AM
David,
For incidents in lower Cecil that involve Kent Co mutual aid, the talkgroup (which you cannot monitor) will often be patched into "VTAC-1" (which you can monitor - see the Cecil page of the database for the freq).
Dave
Old 05-10-2008, 12:36 PM
Well thanks to all. My questions have certainly been answered. I have always said though, where there's a will...
Old 05-10-2008, 6:26 PM
MARINE21078's Avatar
While they do use the one of a kind, VHF Narrowband ProVoice EDACS EA radio system, you CAN still monitor it. The following link will send you to a page where you can download softwear named TeamSpeak Client 2. From there you can hear a direct link set up in the Cecil County EOC that is just for this purpose. You are able to hear the following:
FD MAIN
OPS 6
OPS 7
OPS 8
OPS 9
OPS 10
EMS OPS
This is the only way I can, and gladly monitor, Cecil County Fire/EMS.
As you had said before, when theres a will...theres a way!
Enjoy!
"Its not who you are, but what you do that defines you"
BC350C
RadioShack Pro-33
RadioShack Pro-66
Kenwood TK-3100
TeamSpeak 2 (Cheapest trunked scanner in the world)
