TinEar
If anyone has additional information on talkgroups at either Aberdeen or Edgewood Arsenal, please post them. The problem is that Aberdeen and Edgewood are really two separate nets but listed under one heading in the database. The talkgroups are also jumbled together rather than under their respective net IDs. I had been copying them in a conventional mode simply because I was out of room in the scanner for another trunked system. I just replaced my Upper Eastern Shore Consortium net with Aberdeen to attempt to get some talkgroups recovered. The database no longer lists talkgroups with unknown functions so we can't even try to recover IDs for those that have been noted by others and build on the information. I've recovered these unknowns just today and I'm sure there are many others:
16
496
624
880 (Associated with TG4976)
1296
1392 (Range Operations)
1936 (Probably Military Police function)
2800
11504
11600 (Range Operations)
12944
13040
17680
I also noticed the Aberdeen bombing range is very active today with F16s from the NJ Air National Guard (callsign SMASH) and A10s from the PA Air National Guard (callsign UGLY) operating. The Aberdeen Range uses a control frequency of 248.4 mHz in AM mode if you want to listen.
16
496
624
1296
2800
11504
12944
13040
17680
