Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum - Forum for discussing Radio Information in the State of Maryland.
Old 08-26-2008, 7:06 PM
patrolman123's Avatar
Question Motorola Smartnet
Im adding some stuff into my 396 for my trip to Florida. Can anyone refresh my memory and tell me how to tell the difference between a smartnet motorola type I or II standard or splinter system. Please help. programming tonight.
bc396t, bc235, pro-92, pro-2024, pro-59
Old 08-26-2008, 7:56 PM
Wiki Admin Emeritus
I don't think you need to worry about splinter systems - I could be wrong here, but I think that refers to areas where frequency spacing must be reallocated due to being close to the Mexican border (Texas, for example). As for the definitions for the other terms, you did read the glossary in the wiki, right (hint hint)
Of course, had you gotten a premium subscription and used software, you wouldn't need to be concerned with that (hint hint). I would bet there would be some Florida folks that could give you UASD files for what you need, and most of the better packages can use them as an input source (hint hint)
Enough hints for one day :.> 73 Mike
Old 08-27-2008, 6:27 PM
dcr_inc's Avatar
Default Florida Scanner law
Be careful, Florida has strict scanner laws.. You might ask on the Florida forum about this before you go..
