| Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland. |
04-26-2005, 01:30 PM
Radio signal causing jam near Fort Detrick
Published on Tuesday, April 26
By Liz Babiarz
News-Post Staff
FREDERICK -- For Joan Magaha and her husband, Douglas, the "big problem" with their garage door opener began in January.
"We sit and push and push the button, but the door doesn't go up," Mrs. Magaha said. "... We get stuck outside."
At first, the Young Place resident thought she needed new batteries. She later learned the culprit was a radio signal coming from Fort Detrick.
In November, the fort installed a new Land Mobile Radio communications system, which links Fort Detrick with 10 other installations in the national capitol region.
So far, 36 residents have complained to Fort Detrick about the signal jamming their garage doors.
And more people could be impacted when the radio system is fully launched in the coming days, Army officials warn.
"It's all a matter of timing," said Michael Batt, Fort Detrick's senior telecommunications engineer. "If you're clicking your opener at the same time a transmitter is working, it will jam your door."
Fort Detrick's radio system operates on the same frequency as about 90 percent of remotely operated garage door openers.
The Army's radio signal is so strong it overpowers the signal between a person's handheld transmitter and the receiver. The interference can reduce the range of the transmitter or prevent the door from opening altogether.
"We're doing everything we can to limit the impact on our neighbors," said Col. John Ball, U.S. Army garrison commander. "But this is a system that allows first responders to communicate, and its needed."
Considered a Homeland Security initiative, the radio system aims to eliminate communication problems like those that occurred during the Sept. 11 attacks. It allows first responders to communicate long-range via walkie-talkies.
Right now, the radio system stretches from Site R, in Thurmont, up to Fort Hamilton, N.Y. By 2008, about 120 military bases will have the technology, said Lt. Col. Chris Conway, a Pentagon spokesman.
Because the fort's radio system is here to stay, local residents should contact their garage door manufacturer for a solution, said Christian Devine, Fort Detrick spokesman.
The quickest fix would be to replace some parts so the opener uses a different frequency, according to David Civens, sales manager for Marwest Access Controls Inc., a distributor for several brands of garage door openers.
The do-it-yourself kit runs between $20 and $80, depending on the manufacturer, Mr. Civens said. It's even more if you hire a technician to do if for you.
But Mrs. Magaha doesn't think she should have to pay for a problem Fort Detrick created.
"I'm not about to lay out $80 to fix a situation Fort Detrick is responsible for," she said. " ... I truly believe Fort Detrick is the problem and they should do something about it."
But Pentagon officials are quick to point out that the Department of Defense is the lawful user of the spectrum.
The frequency garage door openers use (390 megahertz) has been owned by the military since 1934. But DOD did not start using it until recently.
According to the Federal Communications Commission, garage door openers and other devices are allowed to operate at this frequency, as long as they don't cause any interference.
Federal law also requires these devices to accept interference from licensed users like the DOD.
Frederick isn't the only place interference has been detected. Garage doors have jammed in Mechanicsburg, Pa., and Eglin Air Force Base, Fla.
"We understand it's causing some interference," Col. Conway said. "But we're trying to balance the need to be a good neighbor with national security."
04-26-2005, 01:43 PM
Re: Radio signal causing jam near Fort Detrick
Welcome to Part 15.
Dear Mr. and Mrs. Magaha,
Read the xxx booklet that came with the garage door opener.
Regards,
Your friendly neighborhood base commander
04-26-2005, 01:52 PM
Looks like someone needed filler before deadline.
Either that or the "reporter" (I use the term to refer to his employment not his profession) has an axe to grind and is trying to generate some public outcry!
04-26-2005, 02:34 PM
Can't you just see her sitting in her car, cussing the government? I wonder how long she sits before getting off her duff, walking inside the house and opening the door from inside. Is she stuck outside for hours? For days? Forever?
Yeah, the "gubmint" should solve all our problems. Personal responsibility? Not in her generation apparently. I suspect she operates under the assumption that someone else is always responsible for everything that makes her life uncomfortable. The whiner generation.
Okay, way off the topic of radios, I know. End of editorial.
Si vis pacem, para bellum
Uniden BC785D (x7) | BC796D (x2) | BC250
Icom R8500 | R2500 | R75
PRO-2042 | PRO-2045
RS Patrolman PRO-2 | Regency Digital FlightScan
04-26-2005, 03:12 PM
What are the chances of Ft Detrick/USArmy buying everybody in the neighborhood new garage door operners?? Slim and none??
04-26-2005, 04:13 PM
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Nuf said!
05-02-2005, 08:03 PM
A garage remote connected to a footwarmer might do the trick
