Nextel BDA
I am looking for a solution to improve in building reception of Nextel. The bulding is approx. 11,000 sq feet with several block walls as room seperators. Outside of the building the Nextel reception is excellent, inside reception status, when in field test mode decreases by 25db, resulting in dropped calls. I have looked at some sites (wpsantennas) that offer solutions, but brought more questions that I have unanswered.
Maybe you guys can help me out with these questions.
I am assuming Nextel is still using 800mhz in the Frederick, MD area, any idea when they will move to the 900mhz? If, and when they move, I will have to purchase and replace the amplifer to match the freq.
Is there a different freq for telephone aspect, or does PTT and voice both use the 800mhz?
Would a BDA help with 800mhz Frederick Public Safety in building reception since the freq are so close to Nextel? Which I guess will only work until Nextel moves to 900mhz.
If any of you can elaborate on the above that would be great.
