Update: The problem appears to have been solved. As I mentioned in the earlier post, switching to CC only mode did not solve the problem, which as it turned out, is only partially correct. When I switched to CC only mode, I did not delete/ lock out the data (voice) channel frequencies in the bank (note that the bank contains other analog frequencies for Anne Arundel County.) As an experiment, I programmed an empty bank with just the primary and secondary cc's and set that to cc only mode. The new bank works perfectly. So I went back and deleted the data channels from the original AA Co bank, and the motorboating is gone.
