Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland.
Old 08-12-2009, 03:01 PM
dmi's Avatar
dmi dmi is offline
Default Trouble Programming NIH TRS [Bethesda, MD] (PRO-106)
I'm having probs programming in the NIH TRS system Scanner Frequencies: National Institutes of Health Trunking System, Various, Maryland using the Radio Shack PRO-106 Handheld
I entered in the control channels into Frequencies section and have tried all the "Types"
Narrow FM: NO
Dwell: 0
DIG AGC: ON
SuperTrack: ON
Multi-Site OFF
Custom Tables:
Table 01:
Lo Chan: 0
Hi Chan: 0
Offset: 380
Base: 406.0000
Step: 12.5
Fleet Map: Type II
I can't seem to figure it out.. I read the manual and looked around the web.. HELP !
What value, if any besides 0, should there be for Hi Chan / Lo Chan ?
However, when I do a manual search limit between 406.0-410.0 MHz I can hear the freqs come up but not when I program the trunking data in..
Thanks,
Jay
Old 08-12-2009, 05:45 PM
freqhopping's Avatar
Try entering 406.0 in the low channel slot too.
Spinning & Grinning
R10 - BC890XLT - BC250D - BCD396T - BCD396XT - BCD996T with a MilTenna LP in the attic.
Old 08-12-2009, 05:53 PM
fmon's Avatar
Narrow FM: NO
Dwell: 0
DIG AGC: ON
SuperTrack: ON
Multi-Site OFF
Custom Tables:
Table 01:
Lo Chan: 0 Change to 380
Hi Chan: 0 Change to 759
Offset: 380
Base: 406.0000
Step: 12.5
Fleet Map: Type II
Thanks,
Jay
See red annotation.
Frank
RR Wiki Programming Shortcuts
Old 08-12-2009, 06:06 PM
fmon's Avatar
After the fact, ARC500, PSREdit and Win500 all imported this system with tables set correctly.
Frank
Old 08-12-2009, 06:11 PM
fmon's Avatar
Jay, this wiki article will provide info on setting various trunking trebles. Object Oriented Scanning tips - The RadioReference Wiki.
Frank
Old 08-12-2009, 08:16 PM
dmi's Avatar
dmi dmi is offline
First.. Thanks so much for the quick response!!
Per fmon's post:
Lo Chan: 0 Change to 380 <<
Hi Chan: 0 Change to 759 <<
That seemed to work
Is 406.0 and 380 the same thing expressed differently.. (HEX?)
I'm new to trunking.. I have the programming cable.. Just no software and have no software...
Looking for a preferably freeware programming software or a good commercial one (or the PRO-106)
ARC500, PSREdit and Win500 were mentioned. Recommendations?
How would one determine the "Lo Chan / Hi Chan"? I guess it's in the Object Oriented Scanning tips - The RadioReference Wiki ??
Do you find these out by decoding the control channel w/ a PC/IF I assume.. (or I probably need to tap the discriminator?)
Lost in a sea of trunking,
jay =)
Old 08-12-2009, 09:14 PM
fmon's Avatar
Per fmon's post:
Lo Chan: 0 Change to 380 << Hi
That seemed to work
hex for 380 is 17C for 406 is 196. In Motorola VHF/UHF Trunking the first go to channel is 380 and the last channel is 759, which gives inclusively, 380 channels available for use. Often this requires more then one table but rarely more then three tables. P25 however, (re-read the Wiki if needed) often uses up to 6 tables or more.
No freeware available other then GRE which is very limited. ScanControl is also available but not mentioned above because it will not integrate with RR database for import to software. It does have a Data Grabber abliity to paste directly from RR. The other three will directly import. I have all 4 but mostly use Win500.
Plus a few other Wiki pages.
The best program for decoding (using PC/IF port) is a free program called Pro96Com at the PSREdit site PSREdit - Configuration Editors for the new GRE line of scanners. Mike V made both programs. Unitrunker is another decoder which works very well.
Frank
Similar Threads
Programming Pro 106 David3708 Scanner Programming Software 5 04-17-2009 03:57 PM
pro 106 STARS programming by hand pogbobo Radio Shack Scanners 10 12-28-2008 06:26 PM
pro 106 programming ? RS2030 Radio Shack Scanners 2 12-23-2008 12:33 PM
Pro 96 Scanner Programming Trouble stiebs81 Scanner Programming Software 7 08-14-2008 12:31 AM
Pro 96 Programming cable bb49490 Radio Shack Scanners 3 12-19-2007 01:36 PM
