Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland.
Old 08-19-2009, 09:45 AM
Default Ocean City/Worcester County EDACS
We now have confirmed site IDs for the Ocean City and Worcester County EDACS systems. OC is site 1 and WC is site 7. Given this and the coordination of talkgroups it strongly suggests that these two systems are networked, not 2 separate systems. I'm inclined to merge the two systems in the database as a result to clean it up. Please let me know if you have any information to the contrary. Thanks.
Eric Carlson
Lead Database Administrator and Manager
RadioReference.com
Old 08-20-2009, 06:20 PM
Dispatcher308's Avatar
Thumbs down Do not change!!!!
Eric they are linked to a certain extent such as shared talkgroups, however it is not a roaming system. I would leave them alone and not comingle the 2 systems as they operate as 2 seprate systems. I hope EDACSTech can explain further or better than I can. But they are not all one system I can assure you from monitoring it while in OC.
Edit** Also while I was in OC doing a ride-along with the fire department you have to switch systems to get to Worcester's other talkgroups that are not linked thru the OC System.
Also how can you change a system in Maryland based on what information you have received, when your in another state and not able to monitor the radio system to see for yourself.
Nathan
Nathan
Every cloud has a silver lining!!! Except for the mushroom shaped ones, which have a lining of Iridium & Strontium 90.
Old 08-21-2009, 06:45 AM
The Worcester County & Ocean City Trunked Radio Systems have separate ownership, management & maintenance. They issue GID's from different agencies but share a common LID database so not to duplicate. A NIM network connection between the two systems allow "some" wide-area talk groups and public safety responders to use both systems for extended coverage, interoperability & backup. It also allows each dispatch center the ability to use both systems.
Similar Threads
Can Anyone Get These Pics For Me? :OFFTOPIC: landonjensen Virginia Radio Discussion Forum 8 04-14-2009 08:06 AM
Hocking County 911 Mess... SLWilson Ohio Radio Discussion Forum 3 02-24-2008 05:44 PM
New to Colorado scanning carcareers Colorado Radio Discussion Forum 19 12-24-2007 04:23 PM
42 new feed links and other updates to my site jasonpeoria911 Streaming / Broadcasting / Audio Recording 6 05-01-2007 12:09 AM
Whitley COunty in Crisis ShawnCowden Kentucky Radio Discussion Forum 5 06-21-2005 12:15 PM
