Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland.
Old 08-29-2009, 07:13 PM
Default Help getting 396XT setup
I just purchased a 396XT and I need some help settiing it up, I'll pay if needed and I just want to start using it. Which programs I should use and how to get the Freq loaded, I currently have FreeScan.
Thanks,
John
Montgomery County MD Police and Fire
Old 08-29-2009, 07:54 PM
Baley's Avatar
Its very easy to do. If I can do it anyone can! Just open FreeScan and click on "File" and then "Import" choose this site in the list and sign in. The price for the premium subscription is well worth it!
Then you pick the area you want to import and it downloads into FreeScan. Hook the scanner to the PC and click on the upload icon. It will load the file into your scanner and your ready to do. You really need to read the Wiki on this forum about FreeScan, it will tell you everything you need to know and its very easy to understand....
Old 08-29-2009, 08:03 PM
Wiki Admin
John, FreeScan will work just fine -- we have its user manual in our wiki, linked below (blue text is a link)...
FreeScan User Guide - The RadioReference Wiki
However, before you jump in, it's best to understand what you are getting into first. The first thing to realize is that these newer scanners take a bit of study. You really can't just jump in. There are many new concepts to learn (and if you say, what about the new RS/GRE models, I'd say exactly the same thing). To that end, our wiki has a FAQ which should prove pretty helpful. Go to the blue toolbar under the logo and float your mouse over Wiki then click on FAQs. Click on the Uniden DMA FAQ and start reading. At the bottom of the article are many links to the Easier to Read manuals. Although there isn't one for the 396XT, there is one for the 396 (which is the older model), and that's going to be helpful. If you understand that, it's a pretty short jump to the XT models.
Now back to the software - most PCs don't have serial ports, but they do have USB ports. You will need a USB-serial converter - Uniden sells their USB-1 model, and Scanner Master has it, along with drivers. Note that some folks have found the Uniden drivers not to work very well - the FreeScan website has the more up-to-date Prolific drivers you can download. There are, of course, others, and since I am lucky enough to have serial ports, I will let others comment on which USB devices seem to work well for them.
The user guide has several comments about USB devices (see the 'Making the Connection' article). Read it carefully - it's very important to get the steps in exactly the right order. In sum, you would install the drivers, then connect your USB device and cable. Go to Device Manager to make sure the COM port the drivers allocated is available.
Finally you have many routes to get data. One way is to purchase a premium subscription and download data into FreeScan. In that same toolbar, slide over to the right and float over About, then click on the appropriate link. In addition, FreeScan can import ARC (BuTel software) and UASD (Uniden's Advanced System Director) files directly. I don't live in Montgomery, but can probably slap a Montgomery file together pretty quickly (I have the 396T) if no one here offers you one.
That should about do it for now. Be more specific about what you want to hear in Montgomery and that'll help folks who may have file(s) you can use.
73 Mike
Similar Threads
FS: Complete Motorola Ham Setup kd0ezq Old Classifieds Archives 6 08-17-2009 11:48 PM
396XT RR Programing? remod Uniden Scanners 4 08-10-2009 09:03 AM
ID SEARCH (396T vs. 396XT) issue roots Uniden Scanners 6 04-22-2009 08:57 PM
Critique Wanted - My SWL Antenna Setup blantonl Antennas and Coax Forum 5 06-16-2008 03:45 PM
Best setup of channels for Denver?? brianmacho Colorado Radio Discussion Forum 11 05-19-2005 07:36 PM
