Seems that Baltimore County's P-25 system is online but only from a couple of tower sites. I found 858.1125 System ID: 0389h-101. I found 858.1125 licensed to Baltimore County WQNX 465 & WNAS500.
If it's anything like the recent switch/upgrade of the BCity system, you may expect reception to ultimately get worse (!!!) - keep you fingers crossed.....
Baltimore County is a big county, if they go low power or directional antennas, you probably would need a lot of fill in transmitters through the county to cover the terrain.
Time will tell my friend
Linear Simulcast CQPSK is all Motorola will install with P25 anymore. At least two of Baltimore County's NEW sites (for the P25 upgrade, not yet in service) employ directional Tx antennas. Scanning Baltimore County post-upgrade will sadly be disastrous.It's not so much a low power thing (although that's exactly what it seemed like at first). It's more about the new simulcast modulation scheme Motorola seems to be deploying these days.
Doubling the towers, lowering the Tx antennas on all towers, some directionalBaltimore County is a big county, if they go low power or directional antennas, you probably would need a lot of fill in transmitters through the county to cover the terrain.
Seems unlikely, probably coincidenceBut now that you mention it.... the reception of the Balt.Co systme "seems" to be coming in stronger recently on my Pro-96. I wonder if it has something to do with the implementation of this new system ?
Uh-oh......
Maybe there's hope that one of the scanner manufactures will address and tweak the issue. HOWEVER, I just got back from Dare County, NC (forced out in a rush) and they have a new Moto P25 system that has LSM, and even some of their Moto portables have trouble handling the multipath.
We can hope that the scanner Mfgs can come up with some sort of tweak to improve the reception of these systems.
I wonder why Balt.County is setting up "directional" TX towers when I would think they would want more of a 360 degree reception around the tower to allow for greater coverage and not less.
Since even some of the Motorola units are having difficulty coping with the system, perhaps Motorola will do some tweaking of their own which will help our scanners receive the signals.
Directionality and lower profiling are mandated by the FCC now to reduce co-channel interference (a near-by system using the same frequencies). Since everyone and their brother wants 20 or 30 800mhz channel pairs, they run out quick in metro areas. Using directional tx antennas and lowering them on the towers makes it possible to "re-use" the system's frequencies closer-by. When Baltimore County built their original 800mhz system in the late 80s, they built 300' and 600' towers, put the transmit antennas at the very top, and let the power flow. Not acceptable anymore.
OCGUARD,
You are quick and accurate with your response... as usual.
Thanks for sharing your knowledge with us. I really do appreciate it.
What you explained makes sense.... but in the case of emergency response and puplic protective services, I still think it make sense to be able to radiate the communcations over a broader area.
But I gotta try to understand the reasoning. I guess overall, it makes sense.
I understand what you mean, but, if our radiated power interferes with another system, it affects their public safety and law enforcement communications, and vice versa. I can tell you that when I worked at Baltimore County 911 in 2001-04, there were times when 3 or 4 of the 20 repeaters had to be taken out of rotation because of co-channel interference on the input side.
This is why the number of transmission sites was more than doubled in planning for the new system; less power but more saturation, keeps the signal within the intended coverage footprint.
So if one was contemplating a new PSR-800 should they wait? I'm only interested in listening to Baltimore County PD primarily. I'd like to purchase it soon but if it's going to be a waste for me I'll pass. Thx.
