| Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland. |
02-01-2012, 10:35 PM
Freq, it looked like a C23. And it said army on the side. The helo and plane both took off and went North following the shore line.
BNN#13
Erma FD
Cape May City FD
02-02-2012, 10:22 AM
I'm preparing for the Super Bowl CAP this weekend (wish I was actually close to Indy so I could hear some fedcom, but this will do) and need to check on some freqs. Obviously, the CAP will probably be 228.900 or 260.900, since those are the local Huntress RCOs, but I wanted to make sure I had boom freqs on hand in case they use them. I have the following from recent events nearby:
247.050
349.550
Can any of you guys add some other common CAP boom freqs?
Jared Soergel @jsoergel949
Radios: BCD396XT, IC-R20 (x2), PRO-76
Spotting gear: Canon EOS Rebel XS, 18-55mm and 75-300mm lenses
02-03-2012, 04:40 PM
Looking up 166016 (should be Tester-20) I came across this site with a bunch of pics from Patuxent NAS.
Lockon Aviation Photography - Trips
1758- SHADOW21 E-6B 163918 heading W west of Harrisburg, PA. 133.475
Also a plane full of Giants fans on that freq too.
Spinning & Grinning
R10 - BC890XLT - BCD396XT - BCD996T- Pro-106 - MilTenna LP in the attic.
02-04-2012, 07:46 AM
ASCOT2208 VC-10 XR808 climbing, from Dover probably. Guessed right and found it with ZDC Harrisburg 133.475. Then to ZOB 132.125.
Spinning & Grinning
02-04-2012, 08:32 AM
WV ANG 167th Airlift Wing to receive C-17's
The 167th based at Martinsburg is to re-equip in 2014. The eleven C-5's currently assigned to it will be replaced by eight C-17's. This change was announced on Friday.
BCD396T / Diamond D130J
02-04-2012, 09:31 AM
247.050
349.550
For the Guard Dog CAP in the Washington DC area 228.15, 262.85, 270.15, 277.35, 294.8, 299.9, 339.6, 341.75, 365.7, 387.9 and 396.2 have been used at various times. Please note that some of these have not been active recently.
02-06-2012, 09:02 PM
Looks like I may have logged the Global Hawk at Patuxent. Today AE17EC showed an ID of 166509. At one point it logged an altitude of 56700ft.
Spinning & Grinning
02-08-2012, 12:32 PM
Crab one-six and Crab one-eight working touch/goes at SBY noontime. looked like working on stols
*I'm not from Maryland, I'm from the Eastern Shore*
02-08-2012, 03:28 PM
Spinning & Grinning
02-08-2012, 08:21 PM
If anyone monitors DEA and Omaha a/c's I have a question. They were doing radio checks between base and other units on Net 1 (165.xxxx) this afternoon. I was only hearing the base unit calling individual stations, by name, real names. But I could not hear them. I thought this freq was a repeater because I usually hear both the base and a/c's. Is it normal to do simplex tests on a repeater freq?
02-09-2012, 03:59 AM
Originally Posted by freqhopping
This was 167966 showing an ID of JA956.
Like the new tail logo.. Adds up as JA is tail code for VX-1 Pioneers NAS Patuxent River, Maryland.
Should read 165956?
If you don't read the newspaper you are uninformed, if you do read the newspaper you are misinformed.
-- Mark Twain
02-09-2012, 04:29 AM
Originally Posted by mark
like the new tail logo.. Adds up as ja is tail code for vx-1 pioneers nas patuxent river, maryland.
Should read 165956?
167956
Spinning & Grinning
02-09-2012, 08:39 AM
Guys,
0935 EST--currently have two 121st FS F-16s (Wild flt) working on 139.9 (usually 121st SOF freq) prob at the PAX ranges. Doing attacks on buildings & chatting about setting delays on ordanace for one floor, two floors, etc.
02-09-2012, 05:28 PM
Hi guys. I have RAVEN flight up at Warren Grove Range (283.100). A2A 293.200 at 1825 local time.
02-09-2012, 09:59 PM
2305z CRAB 16 C-27J up on 126.200 trying Allen C Perkinson tower AAF.
Must have got Wiede instead as apologized.
Long way off from Blackstone AAF a ways down in Virginia not all that far
from North Carolina border...Back home Martin State 0230z.
-- Mark Twain
02-10-2012, 02:10 PM
GAF189 C-160 (3F45B4) now landing at Dulles.
1539- TEAM51 flight with ZDC 133.65, conducting AR at FL250-260. Oddly I don't have it on mode-S right now.
1548- Found them, 85-0032 with an ID of RCH663 and 84-0190 TEAM35. Whoever was refueling is done and will be descending. TEAM51 will be going to McGuire.
Spinning & Grinning
02-10-2012, 02:27 PM
02.10.2012
ADW = Joint Base Andrews AFB-Naval Air Facility Andrews
APG = Aberdeen Proving Ground/Phillips AAF
DAA = Fort Belvoir/Davison AAF
DCA = Washington/National AP
DOV = Dover AFB
JBAB = Joint Base Anacostia-Bolling
KNYG = MCAF Quantico
IAD = Washington/Dulles IAP
NHK = NAS Patuxent River
PT = Potomac TRACON
RMN = Stafford/Regional
ZDC = Washington Center ARTCC
02.10.2012
Had a chance to monitor off an on earlier this morning and early afternoon:
1525Z 133.900 ZDC-Calvert - NAVY 7A 843 (UC-12M 163843 NHK) - 6.5-7-8K QSY PT APP 134.700.
1525Z 133.900 ZDC-Calvert - SCORE 74 - masked PIC 12-9K QSY NHK APP 120.050 dir GYPTS RNAV rwy 32 NHK.
1545Z 121.675 ZDC-Montebello - what sounded like DUCE 51 - will be conducting AR enroute.
1547Z 121.675 ZDC-Montebello - NAVY SD 536 - QSY PT A/D 188.675 @ 17K.
1554Z 125.650 PT DEP - DC 93 (KC-135R 459th ARW AFRC) - to 12K QSY ZDC-Calvert 133.900.
1616Z 128.350 PT APP - VENUS 52 () - rwy 1R app.
1740Z 118.950 PT DEP - ARMY 01052 (UC-35C 00-1052 PATD ADW) - 15K-FL210 QSY ZDC-Montebello 121.675 to FL240.
1746Z 118.400 ADW TWR - MARINE 767 (UC-35D 166767 MASD Det. ADW) - QSY PT DEP 118.950.
Can anyone help with the (t) DUCE 51, ID for SCORE 74 and confirmation of VENUS 52 please?
Thanks!
Tony
QTH: 3 nm. SE KIAD/mobile around Northern Virginia
Radios: PRO-2055, BCD396T, PRO-97, BC3000XLT
Antennas: RS Mobile, DPD Mil Mobile UHF 1/4 Wave, Maldol AL-500H, Watson W-901
02-10-2012, 02:51 PM
Could VENUS52 have been VENUS02 (92-9000)? That's the only thing I have to match the time.
No KC-10s with a DUCE callsign today. Possibly 85-0030 showing TEAM55
1553- E-B 163920 is inbound to Pax and 164388 is leaving.
Spinning & Grinning
02-10-2012, 02:57 PM
Re: VENUS 52/DUCE 51
Don't think so - did not have that VC-25 xmtr sound, more like a C-32 this one. Thanks for checking!
Just had a UNID 41 up with ZDC-Marlinton 319.000 FL240 @ 1952Z. He's fading now so probably won't snag an ID. Sounded like TILEY or RILEY.
Tony
02-10-2012, 03:07 PM
99-0003 departed at 1355 as S791
98-0001 departed about 1230 as VENUS91.
1625- P-8A 167955 JA955 with ZDC Calvert 133.9. Inbound for Pax.
Spinning & Grinning
