| Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland. |
01-25-2012, 04:36 AM
Maryland FIRST 700mhz TRS
Hey all,
I've seen official rumors that Maryland is working on a statewide digital TRS termed a 'first responders' net:
700 MHz System
As it says, Motorola was given a notice to proceed back in 2010.. anybody have any idea how far along they are with this project (at least in service region 1A) or any further information?
01-25-2012, 07:14 AM
Wiki Admin Emeritus
Actually at least in central Maryland, PG county has the distinction of having the first 700 mhz trunk system...
and as for the so-called statewide system, I haven't heard anything in a long time on this subject. Not surprising, with the budget shortfall...best regards...Mike
01-25-2012, 07:21 AM
Location: Mpls, MN. (But work in NY,CA,MI,AZ,KY,TN, And IN.)
FYI FiRST=First responders Interoperable Radio System Team not 1st.
01-25-2012, 01:56 PM
The state has put up a half dozen or so towers in southern Maryland and have mounted some yagi's on them but that is all the progress that I have seen so far.
John Guyton
N3ARN
01-25-2012, 09:05 PM
Wow, that's coming up pretty fast.
01-26-2012, 08:53 PM
Hopefully it will be reasonably receivable here in Newark, DE.
I can't wait to monitor the proposed air-to-ground channels!
Al ---KB3YCL
Uniden BCD996XT----Wouxun KG-UV3D
Only an idiot would use a rotator with an omni!
01-27-2012, 10:33 PM
That's outstanding, good step-up from the VHFL clunker system MSP is on right now- and that presentation shows the timescale pretty well. Thanks CqDx.
01-29-2012, 05:35 PM
Is this Statewide TRS going to replace some of the older county TRSs or will it just co-exist with them?
Also is the SW TRS going to be P25 phase 1 or 2?
Al ---KB3YCL
01-30-2012, 06:39 AM
Looks like it's designed to co-exist unless the county wants to jump entirely on board- looks very county-governance hold-hand-y.
01-30-2012, 10:08 AM
Phase Two, confirmed thru state documents and Motorola promo material. Moto is really using this as an example of their first big Phase 2 project.
02-25-2012, 05:45 PM
Confirmed. Pikesville tower.
Matt
"If the tallest building in your county is a grain silo, you DON'T need 800mhz!"
02-25-2012, 07:55 PM
Any Tg's popping up yet or just the control signal??
02-25-2012, 08:13 PM
Are these 700mhz trunked county licenses part of the statewide system? They are in the Region 1 area of the FIRST project.
WQNB667/WQNH714 Carroll Co
WQNH702 Harford Co
WQNH763 Anne Arundel Co
WQNH768 City of Baltimore
WQNI382 Howard Co
WQON288 Frederick Co
Spinning & Grinning
R10 - BC890XLT - BCD396XT - BCD996T- Pro-106 - MilTenna LP in the attic.
02-25-2012, 08:28 PM
Just the CC. At this hour, I wouldn't expect anything more.
Matt
02-25-2012, 08:48 PM
Just for something new tried my old Pro-96 out tonight unlocking 700 band via Win 96 software
Getting strong CC here in Cecil County on 773.3125 so far..
Assume from Northeast MSP Barracks site.
OK getting some ID's now 2155 pm
47344 47248 47216 47280 47312 35568 so far they just pop up for a second then gone.
Real strong signal on the rubber ducky
20 minutes later getting new ID's
59632 59504 59600 59472
If you don't read the newspaper you are uninformed, if you do read the newspaper you are misinformed.
-- Mark Twain
02-25-2012, 09:37 PM
Must be some signal testing... keep us updated as to when you start hearing voice.
What software are you using to log?
02-25-2012, 10:03 PM
No software..Just watching ID's come and go on CC freq 773.3125
They almost seem to be changing ranges every 20 min or so.
First was 47*** then 59*** now 35*** Must be random testing.
Will keep watching for pattern and limit search for voice coms from time to time.
Cecil County is part of the Region1a phase 700 deployment with the funding and Kent County
Will be nice for local MSP to finally get off the low band radios.
Tonight midnight CC is so strong can receive CC without any antenna on Pro-96..
Wondering since no cell phone interference like 800 band they can up the wattage or just
cleaner 700 band is the difference.
-- Mark Twain
02-26-2012, 01:24 PM
What scanner are you using? You may justbe close to transmitter... i know on some local 800 towers i can get the CC withoutthe antenna as well.
