| Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland. |
09-30-2012, 1:42 PM
programming pro 96
for some reason i cannot pick up Washington County FD on my pro 96. I programmed it with the info from radio reference and the additional freq's it said to add and offsets.
Frequency Table:
0: Base: 851.00625 MHz, Spacing: 6.25 kHz
1: Base: 762.00625 MHz, Spacing: 6.25 kHz
2: Base: 452.00000 MHz, Spacing: 6.25 kHz
Table for Pro-96/2096:
Ch Lo 8192
Ch Hi 12287
Base Freq 452.0
Offset 8192
Step 6.25
Anyone have any suggestions/hints?
09-30-2012, 2:16 PM
I don't believe a Pro-96 is P-25 compatible, however I could be wrong.
09-30-2012, 2:22 PM
i have done that with freq tables 0, 1, 2 and still nothing
09-30-2012, 3:32 PM
did ya follow the screen shots on that page you will need all the tables
10-01-2012, 4:38 PM
yes i did. didnt work today cause i had the channels "off" and i needed a computer to turn them on. I will see if it works tuesday when i head to work in wash county.
10-02-2012, 3:34 PM
ok, didnt work today. I did the reband like you suggested
10-02-2012, 5:44 PM
check your PMs
10-02-2012, 5:50 PM
lol i am an amateur with this . PMs?
10-02-2012, 5:59 PM
private messages at top right when you're logged in
10-02-2012, 6:05 PM
post the.p96 file in the forum so peeps can look & track down any errors etc
10-02-2012, 6:26 PM
3600 bps CC NORMAL
9600 bps CC NORMAL
MOT Custom Table 406.00000 380 25.00
MOT Multi Table # CH Lo CH Hi Base Freq Offset Step
800 mhg reband 0 440 559 851.02500 440 25.00
1 0 719 851.01250 0 25.00
2 720 759 848.00000 0 25.00
3 815 831 846.62500 0 25.00
4 961 1022 843.40000 0 25.00
5 958 958 868.97500 958 25.00
little off with the posting and lining up sorry
10-02-2012, 7:31 PM
I meant the actual file you are loading in the scanner ..... rename the extention to txt ex myfile.txt & add as an attachmnet
10-02-2012, 8:33 PM
Wiki Admin Emeritus
We're clearly mixing apples and oranges here, and coming up with grapefruits :.>>
I don't have a 96, but I think I see your problem. First off- rebanding has absolutely nothing at all to do with this system, since it's UHF. I would wipe those values out.
Next, examining the database entry for Washington county, I *think* you need the following settings;
(assuming here you're using Win96 - ARC96 won't be that far different...)
As this is a UHF P-25 system, you would leave the 3600 CC as normal, but the 9600 should say UHF
The custom table should be:
Line 1: Channel Lo 8192 Channel Hi 12287 Base Freq 452.0 Offset 8192 Step 6.25
These values come directly from the db. The other lines should likely be zeroed out
The freq table is likely what is derived using a Uniden scanner which has the capability to derive these stats automatically. It really should be labeled better in the db
If someone does get this working right, please post a pic so it can be captured into the wiki. It's very likely other 96/2096 owners trying to hear this system will have similar problems.
HTH...Mike
10-03-2012, 7:17 AM
I have my Pro-96 set up like this. 9600 CC mode / NORMAL Base: 452.000 Offset: 8192 Step:6.25Khz
REALISTIC PRO-53 , BEARCAT 145XL , BEARCAT 147XLT , RADIO SHACK PRO-46 , PRO-74 , PRO-2042 , PRO-2018 , PRO-96 (X 2)
10-03-2012, 1:21 PM
I need to correct that last post to read 9600 CC Mode is set to Table..............
10-03-2012, 3:39 PM
ok Mark, changes are : 9600cc -custom table.....and the above settings. ok, i try that tomorrow. I will let you know if it work. I been working on this issue for 3 months lol
10-04-2012, 3:11 PM
thanks markandjere, that configuration worked. Thanks everyone for they're help.
