Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland.
Old 12-11-2013, 3:55 PM
Default Harford County MSP SAM unit?
I hear them all the time. What do they do and what's the acronym stand for?
Sent from my SCH-I545 using Tapatalk
Old 12-12-2013, 1:29 AM
In what context and on what net do you hear them?
APX7000 UHF1/700/800, PSR800, KG-UVD1P
XPR 7550, M7100, P7100IP user
OC / UMBC
Old 12-12-2013, 2:08 AM
They are on the Harford county police channel. They identify themselves as Sam XXX. I figure it's either a specialized unit or maybe a joint unit consisting of multiple agencies. They work very closely with State Police and although I don't hear Msp as much on there channel I do hear them responding to same calls
Old 12-12-2013, 7:03 AM
DisasterGuy's Avatar
In Harford County all units have an alpha identifier for their agency. SAM is a Sheriff's Office unit.
Old 12-12-2013, 1:05 PM
Yes I figured they are Sheriff's unit. I wanted to know their purpose. Are they a special holiday team, are they like a flex quad that goes out looking for certain crimes, etc?
Old 12-12-2013, 1:36 PM
All HCSO units are SAM, Bel Air PD is Boy, Aberdeen PD Adam, HDG PD Henry.
Old 12-12-2013, 9:38 PM
The idea behind this was, when the 800mhz system went online, police agencies had access to each other's talk groups. Previously, all law enforcement agencies in Harford County had number-only unit identifiers. So if Bel Air Police had a unit 200, and HSCO had a unit 200, it could get confusing. So all HSCO units took on the prefix "SAM" and the other town PDs took on prefixes as DisasterGuy mentioned. SAM means nothing other than the fact that it's an HSCO unit. The number that follows is the officer's badge number.
Matt
"If the tallest building in your county is a grain silo, you DON'T need 800mhz!"
Old 12-12-2013, 9:41 PM
Ahhhh ok. So this is a shared channel? I hear them on the Hfco channel designated as dispatch a16 Southern
Old 12-12-2013, 9:45 PM
I'm pretty sure that all Harford County law enforcement agencies have the capabilities to operate on each others' talk groups.At very least, all of the town PDs can operate on HCSO's dispatch talk groups.
Matt
Old 12-12-2013, 10:40 PM
Where I am from badge numbers meant nothing. They were reusable i.e. if a officer retires, quits, gets promoted, gets killed, etc. the badge gets thrown back in the pool for reissue. I doubt without extensive research one would not be able to find out the identity of an officer by a badge number alone. It would probably be in the anals of the quartermaster unit. Judging from the way they ran that place I doubt they would even have an accurate history. Each officer upon being hired is given a sequence number (commonly referred to as a short number) that is unique to that officer only. This started in the 70s and began with A001 when they reached A999 they would move on to the B. This practice continues today and I believe there into the J series. As for identifying an officer without the short number you could narrow it down by using a sequence of numbers and letters but those would only be good if you knew the day and time he was working. For instance there were nine districts starting with (1) at the 12 o'clock position and moving clockwise i.e. 2 would be northeast, 3 would be the Eastern and so on. The next digit would be a letter for the shift working i.e. A would be for the midnight shift midnight till 8 AM, B would be four day work 8 AM to 4 PM, C would be for the mid-shift 4 PM to midnight. The next digit would be for the sector(commonly three sectors per district) but some larger districts had a sector 4. The next digit would be the car number with in that sector(commonly 1 – 7), however as the budget crunch happened and funds were lost so were police officers thus the amount of cars per sector dwindled to as little as 3 – 5). So for instance if you were working the Eastern District, midnight shift, sector 2, car three your unit designation would be 3A (adam) 23 or 3A23. As I said this does not necessarily identified that particular officer as he may be working car 4 the next day or even be in a totally different sector if they were short officers. Supervisors were identified as 10, 20, 30, etc. district commanders would be 300 400 500 etc. police Commissioner unit 1, deputy commissioners unit 2 etc.
then you had specialized units which usually were a four digit numerical code i.e. 3032 4055 etc. the first digit usually referred to the district but downtown specialize units could have a variety of numbers which were confusing at best. While just a history of the Baltimore police most you guys probably already knew that
Old 12-13-2013, 5:11 AM
If you go back in history to the early days of radios in cars each county sheriff and PD had assigned number blocks in the state law enforcement communications plan with the idea that radio identifiers would be unique statewide. I have not seen a copy of it in many years.
Old 12-13-2013, 10:38 AM
Where I am from badge numbers meant nothing. They were reusable i.e. if a officer retires, quits, gets promoted, gets killed, etc. the badge gets thrown back in the pool for reissue. I doubt without extensive research one would not be able to find out the identity of an officer by a badge number alone. It would probably be in the anals of the quartermaster unit. Judging from the way they ran that place I doubt they would even have an accurate history. Each officer upon being hired is given a sequence number (commonly referred to as a short number) that is unique to that officer only. This started in the 70s and began with A001 when they reached A999 they would move on to the B. This practice continues today and I believe there into the J series. As for identifying an officer without the short number you could narrow it down by using a sequence of numbers and letters but those would only be good if you knew the day and time he was working. For instance there were nine districts starting with (1) at the 12 o'clock position and moving clockwise i.e. 2 would be northeast, 3 would be the Eastern and so on. The next digit would be a letter for the shift working i.e. A would be for the midnight shift midnight till 8 AM, B would be four day work 8 AM to 4 PM, C would be for the mid-shift 4 PM to midnight. The next digit would be for the sector(commonly three sectors per district) but some larger districts had a sector 4. The next digit would be the car number with in that sector(commonly 1 7), however as the budget crunch happened and funds were lost so were police officers thus the amount of cars per sector dwindled to as little as 3 5). So for instance if you were working the Eastern District, midnight shift, sector 2, car three your unit designation would be 3A (adam) 23 or 3A23. As I said this does not necessarily identified that particular officer as he may be working car 4 the next day or even be in a totally different sector if they were short officers. Supervisors were identified as 10, 20, 30, etc. district commanders would be 300 400 500 etc. police Commissioner unit 1, deputy commissioners unit 2 etc.
Very informative, but this is after all Harford county being discussed, and each county loooves to do things differently than their neighbors.
OC / UMBC
Old 12-13-2013, 10:51 AM
That's true but since I am the OP I hijacked my own thread!
Old 12-13-2013, 2:59 PM
Fair point! Being from an agency that uses badge numbers over the air instead of sectors, I'm quite used to them... does help know who exactly's dealing with something.
OC / UMBC
