Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum - Forum for discussing Radio Information in the State of Maryland.
Closed Thread
  #61 (permalink)
Old 03-12-2014, 12:09 AM
listen13579's Avatar
Did you hear any callsigns?
Originally Posted by freqhopping View Post
I just went by Dulles and saw the Comco 757 N226G sitting there by the Dulles Jet Center. That was a surprise.
Maybe staging for govt types to get out of here?
  #62 (permalink)
Old 03-12-2014, 5:19 PM
freqhopping's Avatar
It was parked.
Spinning & Grinning
Alinco DJ-X11 - BC890XLT - 436HP - BCD396XT - BCD996T- PSR-800 - Pro-106 - MilTenna LP in the attic.
  #63 (permalink)
Old 03-12-2014, 7:35 PM
AR activity on 336.1. SLUFF07 is one of them it sounds like.
Spinning & Grinning
  #64 (permalink)
Old 03-16-2014, 7:09 PM
HM1529's Avatar
Pennsylvania DB Admin
I was streaming KMDT approach this evening and heard HAVOC-91 working with the controller on approaches. Any ideas on who this might be?
  #65 (permalink)
Old 03-17-2014, 3:09 PM
jkahn's Avatar
Not to be too OT, I've just gotten the SDR dongle, I have the software, would anyone PM me with a little detailed help with the install, setup and tuning to monitor the Milair freqs on an old laptop? I have tried to follow the topic in the wikis, but I think I am a little dense.
JK
JRKahn
Uniden HP-2 Extreme; Uniden HP-1 Extreme; BCD436HP(DMR); 996T; 250D; & a multitude of unused older Unidens, some with crystals! .....and a GRE PSR-800 (that thinks its a W-1080 with DMR) !
  #66 (permalink)
Old 03-17-2014, 4:15 PM
Wiki Admin Emeritus
You're more likely to get an answer here...
Software Defined Radio - The RadioReference.com Forums
  #67 (permalink)
Old 03-17-2014, 4:29 PM
Tech792's Avatar
Ron's list shows the following:
HAVOC C-130H 317th AG Dyess AFB
HAVOC B-52 2ND BW 96TH BS BARKSDALE LA
HAVOC F-15, 104th FW MA ANG Barnes ANGB MA
My guess is it was the F-15s out of Barnes.
  #68 (permalink)
Old 03-17-2014, 8:00 PM
HM1529's Avatar
Thanks. Where'd you dig that up from? I have not been frequenting this thread much the past few months. I did a search for "Havoc" in the thread before posting but came up empty.
Thanks for the leads. I guess without getting a visual, there's no way to tell for certain.
Anybody on the list keep track of army aviation? I have a spreadsheet I put together for helos at FTIG and KJST here in PA. It's a work in progress.
  #69 (permalink)
Old 03-17-2014, 10:41 PM
Tech792's Avatar
I should have included the link
Untitled Document
  #70 (permalink)
Old 03-18-2014, 8:19 PM
nyair1's Avatar
Default WNY Log
3/5 -
301.600 - DeeCee ? AR with Colt 01 flt in Duke MOA
271.400 - Colt flt a/a
353.850 ZOB - Colt 01 flt of 2 Alpha 10's exiting Duke Airspace VFR 13,500 for R5802
3/6 -
301.600 - Steel 62 AR Colt 01 flt in Duke MOA
353.850 ZOB - Colt 01 flt departing Duke MOA to the SE direct Ravine at 11000
3/7 -
353.850 ZOB - Axeman flt in the Duke Airspace
266.600 - Axeman flt ACM in Duke
301.600 - Axeman flt ACM
271.400 - Colt flt a/a and ACM
353.850 ZOB - Colt 01 & 02 will depart VFR
338.300 ZNY - Axeman flt of 4 in the block 15-16
3/11 -
301.600 - Steel 62 AR Axeman 01 flt in Duke MOA
Chris
Western NY
Uniden 996XT(2), 15X(2), 396XT, Sangean 909X, 30ft RS ST-4 Discone Antenna, EF-SWL
  #71 (permalink)
Old 03-22-2014, 10:34 AM
BM82557's Avatar
AE065F 60-0346 MOTWN02 KC-135T at 34000'
  #72 (permalink)
Old 03-23-2014, 10:08 PM
Tech792's Avatar
03/23/14
2200 local- solid signal orderwire 366.60
  #73 (permalink)
Old 03-23-2014, 10:09 PM
03/23/14
Probably E-4B GORDO15 that was passing west to east across lower PA not too long ago.
Spinning & Grinning
  #74 (permalink)
Old 03-25-2014, 11:15 AM
Tech792's Avatar
03/25/14
1214 local- COSMIC 41/42 with HUNTRESS. Sounds like they intercepted a TOI on 260.90. Possibly training.
  #75 (permalink)
Old 03-28-2014, 8:26 AM
mdmonitor's Avatar
Untitled Document
I have an updated version (March 2014)--if anyone interested e-mail me at mdmonitor1@verizon.net
Ron
  #76 (permalink)
Old 03-29-2014, 5:33 AM
Currently passing through the area on 396.2
GOLD51 KC-10 85-0032
GOLD52 KC-135 62-3547
GOLD53 KC-10 87-0118
PETRO01 KC-10 86-0036
Spinning & Grinning
  #77 (permalink)
Old 03-29-2014, 11:00 AM
RAVEN11 with ZDC Blackstone 235.625 12, 13, 14 also with him. They will be splitting up soon. Returning to Martin State. Air to air on 266.6
Got 79-0165 on mode-s. Displayed callsign is AC165.
1240- 165 must be part of a second RAVEN flight, 21,22,23 I'm now hearing on 235.625.
1245- Maybe a third flight. RAVEN31,32
SAM544 C-20B 86-0201 is around somewhere.
I've got mode-s/ADS-B once again using an SDR dongle,RTL1090 and PlanePlotter. I picked up on C-32B 02-5001 earlier as it was heading west through the Hagerstown area. I'm still watching it on Plane Finder, now over NW Indiana.
I'm using my DPD mode-s antenna I had used with my Radarbox. I might actually be getting better range too.
1247- SPAR533 C-21 84-0118, CNV4106 C-40A 165836 and STEEL85 KC-135 58-0054 in the area
Spinning & Grinning
  #78 (permalink)
Old 03-29-2014, 6:18 PM
C-32B 02-5001 back in the area, east of Richmond and looks like it's going into KORF. It had gone all the way out to Utah before heading back here.
1928- Headed off the coast at FL175 and lost it.
1935- Now see it just about on the ground at KORF.
1933- GAF593 10+27 is on final for Dulles.
Spinning & Grinning
  #79 (permalink)
Old 03-30-2014, 5:38 PM
Just heard an EAM on 311.0. WAVY/WAYPETE was calling RADIAN. Says they'll see RADIAN in a few.
There is a E-6B off the coast near Ocean City, MD.
Also E-4B 75-0125 CHUNK85 is somewhere in the area.
Spinning & Grinning
  #80 (permalink)
Old 03-30-2014, 9:06 PM
nyair1's Avatar
Is that 235.625 a new a/a for the MD Ang A10's? I haven't seen that one before.
Chris
Western NY
Closed Thread
