I don't have a favorites list. I will re enter the zip code
Ah ---- I don't think that is going to work either...... and here's why I think that...
The location based scanning (by zip code, GPS, etc.) is based on location data that is stored in the RRDB and then imported via the library updates....
It appears to me that when the new Department of "Queen Anne's County" was added to the RRDB, they failed to enter any location data for that department/group of talkgroups. Therefore, it appears to have defaulted to 0 Lat and 0 Lon which Paul O would tell you is out in the middle of the ocean.
The DB admins need to fix this....
So, the easy option (again) is:
1. hope they correct it in the RRDB before the next library build
2. repeat the steps you took this week after they do that
The other options include (but are not limited to):
- create a favorites list and setting the location data for QA County properly before copying it to your scanner....
- manually set your location to 0/0 but keep in mind that other channels from the library properly configured with location information will them go silent (not a good option)
I could probably come up with some other options but.....
