Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum - Forum for discussing Radio Information in the State of Maryland.
Old 06-17-2017, 10:05 AM
Question Washington County Fire Talkgroups
I noticed an update this morning to most of the fire ops talkgroups. Just looking for a bit of clarification on how these channels are now used, as the submitter has chosen not to allow private messages...
Does SUP refer to supervisors? I suppose it could also be for suppression.
Does STG refer to staging? I see that those changed from the Fire Police talkgroups.
How are the ATG talkgroups actually used? I've never heard anything on them.
Old 06-19-2017, 2:54 PM
Dispatcher308's Avatar
SUP could also mean supply or Water Supply
ATG could be an all call for the other talkgroups in the same zone, group.
Nathan
Every cloud has a silver lining!!! Except for the mushroom shaped ones, which have a lining of Iridium & Strontium 90.
Old 06-19-2017, 3:09 PM
EMTB644's Avatar
SUP is support and STG is staging.
Old 06-19-2017, 10:09 PM
Thanks for this information. In particular, how exactly are these used? Can you provide a bit more explanation of how they are used differently? I would imagine that Ops would be for crews working the fire scene, EMS for supporting medical, Support for water and air supply, etc and staging for initial setup perhaps?
Also, I noticed that the talkgroups for Ch 3 and 4 staging are missing -- perhaps you would know this info?
Hoping you can clarify the use of the ATG talkgroups. I'm not sure if I'm correct or not, but it seems as though one of the main zones (Ch 1 for example) could be in use for a working fire. A person could then get on the ATG channel and would be heard on all of the other Ch 1 talkgroups like Ops, EMS, Staging and Support. If that is correct, then would it technically be unnecesary to have those ATG channels programmed into the scanner at all since the comms would be heard on the regular zone channels?
Old 06-22-2017, 4:26 PM
EMTB644's Avatar
FIRE TAC 3 STG is TG 13501
FIRE TAC 4 STG is TG 13600
I haven't heard ATG (Announce) talkgroups used so I can't answer your question about the need to program each ATG talkgroup. FIRE TAC 5 ANN is TG 13606.
Old 06-22-2017, 10:25 PM
Thanks for all the help with those talkgroups. Would you be able to completely verify any of the info for the events and training talkgroups, or add any additional info elsewhere?
Old 06-24-2017, 11:05 AM
So I have had 13479 listed in my scanner as "EMS 1" for a while. Listening this morning, it sounded like it was being assigned as "PS 1" as some kind of an EMS ops channel. I see it's listed in the database as Fire Tac 4 EMS as per the recent talkgroup changes that were made on June 15th. Is this correct?
Old 06-25-2017, 9:40 PM
EMTB644's Avatar
TG 13479 is now designated Public Safety 1 (PS 1). It was previously called EMS 1.
TG 13500 is now designated Public Safety 2 (PS 2). TG 13500 was previously designated as FIRE 1.
PS-1 and PS-2 are used for communications between fire and EMS responders on an incident. The majority of operations after the initial dispatch will be heard on PS-1 or PS-2.
TG 13504 is now FIRE TAC 4 EMS.
Old 06-26-2017, 10:21 PM
Any idea about 13536, which was previously listed as Fire 2 Mutual Aid?
Would you have any info on the patch talkgroups? I think I may have heard a reference to "Patch 1" the other day...
Old 07-01-2017, 10:00 PM
EMTB644's Avatar
Gilligan, I have no info on TGID 13536. Have you heard any radio traffic on this TG?
EVENT A1 (TGID 13611) and EVENT A2 (TGID 13612) are active tonight supporting fire works events.
MSP Trooper 3 used TAC 1 SUP (TG13468) during response to Washington County this evening.
Old 07-01-2017, 10:41 PM
Do you happen to know if these are generic public safety (not fire-specific) event channels or if they are only for fire? I haven't monitored traffic on these channels but am thinking they are using those in place of the old EOC 1, 2, 3 channels, which would mean they would be shared between all public safety services (fire, EMS, police) at a particular event...
Old 07-04-2017, 8:58 PM
EMTB644's Avatar
Various public safety services can be assigned Special Event talkgroups. EVENT A3 (TGID 13613) and EVENT A4 (TGID 13614) are active tonight.
Old 07-06-2017, 12:41 PM
EMTB644's Avatar
Washington County Radio Techs testing today on FIRE TAC 3 OPS (TGID 13474).
Old 08-04-2017, 5:29 PM
What is 13536 now used for? It used to be Fire 2.
Also, I noticed that instead of saying, t"ruck 1 with 2" (while responding to a call), I'm now hearing something like "truck 1 with 2 and 2" -- what are they referring to with the X by X format?
Old 08-05-2017, 10:21 AM
Septa3371CSX1's Avatar
Could be referring to the number of pack and non-pack guys they have on board. On most trucks the driver's seat does not have a pack in it and there may be one or two jump seats in the back that don't have a pack.
Joe Butler
Pro 95, Pro 97, Pro 106, Pro 651, Pro 668, & PSR 310 - Scanning the Delaware Valley!
Septa3371CSX1@aol.com
Victory5318@gmail.com
Old 08-05-2017, 10:46 AM
troymail's Avatar
In Anne Arundel County, they say things like "2 with 1" .... meaning "2 total personnel and 1 is an officer"....
It could also have something to do with qualifications - full vs. probationary (limited capability) firefighter .
Unication G5(UHF)
Old 08-05-2017, 12:26 PM
EMTB644's Avatar
TGID 13536 is FIRE 2 MUTUAL AID
"Truck 1 with 4 and 3" means a total of 4 responders, 3 are certified.
TGID 13465 ADMIN 1 active today as officials were accessing overnight storm damage in Washington County.
Old 08-06-2017, 5:03 PM
EMTB644's Avatar
Should have said TGID 13456 was used by Washington County officials assessing storm damage.
TDIG 13465 ADMIN 1 active yesterday.
Old 08-07-2017, 5:49 PM
So if "Fire 1" became "PS2", what became "Fire 1"? Doesn't make much sense to have a Fire 2 without a Fire 1... Also it appears that the same situation is going on with EMS 2 -- no EMS 1 is listed any longer...
Old 08-07-2017, 5:51 PM
13465 used to be Hagerstown Fire Dept. So that has now changed as well?
