Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum - Forum for discussing Radio Information in the State of Maryland.
Old 09-08-2017, 6:53 AM
Default Cecil County Dispatch
My apologies if this has been answered before I didn't happen to see it. I'm sure many have found out the hard way that 155.5275 doesn't work on lots of the older scanners. Is there any sort of rebroadcast of this channel not listed in the db that is scanner friendly?
Old 09-08-2017, 8:54 AM
Wiki Admin Emeritus
It will work just fine in most older scanners; the frequency will get rounded up, and the audio will be lower than you're used to. If you're too far away, you may not hear it well, if at all.
Old 09-09-2017, 8:39 AM
Thanks. Yea I'm trying to hear this on a Uniden BC560xlt. What frequency does it get rounded up to 155.53?
Old 09-12-2017, 1:07 PM
Wiki Admin Emeritus
Somewhere in that neighborhood, depending on what step size the 560 uses for VHF...Mike
Old 09-12-2017, 8:17 PM
Mark's Avatar
Yes have programmed on regular scanner as 530 regular FM mode.. Works fine.
'Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy; its inherent virtue is the equal sharing of misery." - Winston Churchill
Old 09-13-2017, 7:01 PM
Thanks guys.
