Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Maryland Radio Discussion Forum
Maryland Radio Discussion Forum Forum for discussing Radio Information in the State of Maryland.
Old 09-07-2006, 08:34 PM
irishman75's Avatar
Default Scanner Recording
Im trying to record from my scanner (bc296d) into my computer through the line-in jack I'm trying to find a program that is easy to use and only records when there is something coming voer the scanner. If anyone is familiar with Baltimore City, I'm trying to record Box Alarms. If anyone can help I'd greatly appreciate it. Thanks
I can be reached at leftydrummer@comcast.net
Old 09-07-2006, 08:38 PM
consys's Avatar
I've had good results with this:
http://www.sagebrush.com/recall.htm
John S
So many frequencies, so little time...
Old 09-07-2006, 10:05 PM
rbm's Avatar
rbm rbm is offline
Scanrec is a pretty good program and easy to use.
http://www.davee.com/scanrec/
Old 09-08-2006, 04:45 AM
Wiki Admin Emeritus
Yes, both are quite good but don't discriminate between Box Alarms and any other voice traffic. I don't know of anything that does 73s Mike
Old 09-08-2006, 08:17 PM
1080iAddict's Avatar
You would need a Uniden 396, 996 or other tone decode radio. Then set the system to recognize the tones for box alarms. Once that is done, use one of those programs and it will only record audio when the tone alert releases the squelch. Of course, you could not use the radio for other purposes so it would need to be a dedicated radio for that purpose that sits on the tone channel.
Old 09-09-2006, 12:10 AM
Llwellyn's Avatar
Unfortunately, we've not had much (any, in my case) luck getting the 396T to alert on the box alarm tones; they don't play them long enough for the warble to activate the alert tone and open the squelch. It could also be the warble itself alternates too quickly to be detected properly. I tried with several different recordings to no avail, and it has never worked on a live dispatch either.
Technician Class K3DSL - Arundel Village, Brooklyn, Maryland
Current Equipment: BCD396T (voice follow), Pro-2006 (Unitrunker)
Old 09-09-2006, 11:25 PM
Hmmm. Never tried baltimore City. It does work for Baltimore County's warble tone.
Similar Threads
Scanner Recording Software... MacombMonitor General Scanning Forum 9 12-29-2009 08:19 PM
Recording your scanner? xpawel15x Streaming / Broadcasting / Audio Recording 40 10-27-2009 06:13 AM
Best vendor for BCD396T? ndparts Uniden Scanners 50 07-17-2008 08:51 PM
Question about settings for recording scanner audio photodreamer Tavern Archives 2 12-05-2005 10:52 PM
Recording transmissions from scanner scanrrman Scanner Programming Software 10 04-25-2005 07:28 PM
