Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Massachusetts Radio Discussion Forum
Massachusetts Radio Discussion Forum Forum for discussing Radio Information in the State of Massachusetts.
Old 03-01-2009, 4:16 PM
Default UMass Amherst PD
I have umpd in my scanner. it is annoying because it seems like 20 seconds it sounds like a mic is key'd up for less than a second. Is there anyway to program arc330 to wait for a longer transmission? or does anyone know what it is?
Old 03-02-2009, 11:19 AM
ecps92's Avatar
UMA is an LTR you need to program the Radio for LTR Trunking with the channels in Logical Order. What you hear is the system polling.
Nothing new has been submitted since early 2008
so any changes from the RR DB would be great.
I would suggest reading the WIKI on LTR and it will help you deceipher
the info, to post to the RR DB with some valid updates.
Logic Trunked Radio - The RadioReference Wiki
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 03-02-2009, 12:36 PM
so what is system polling
Old 03-02-2009, 12:49 PM
ecps92's Avatar
Typically on LTR systems, each of these controllers periodically sends out a data burst (approximately every 10 seconds on LTR Standard systems) so that the subscriber units know that the system is there. The idle data burst can be turned off if desired by the system operator. Some systems will broadcast idle data bursts only on channels used as home channels and not on those used for "overflow" conversations. To a scanner user the idle data burst will sound like a short blip of static like someone keyed up and unkeyed a radio within about 1/2 second. This data burst is not sent at the same time by all the channels but happen randomly throughout all the system channels.
Bill N1KUG
Old 03-02-2009, 1:16 PM
so is it possible to block that out on a scanner?
Old 03-02-2009, 1:53 PM
ecps92's Avatar
Yes, by setting your Scanner up in Trunked Mode for an LTR Trunk.
What model scanner? Have you read the Wiki link, yet?
Bill N1KUG
Old 03-02-2009, 1:55 PM
its a BR330T scanner
Old 03-02-2009, 2:16 PM
ecps92's Avatar
BR330T - The RadioReference Wiki
Your Radio can handle LTR trunking, take some time to read the manual
for entering Trunked Frequencies. Remember on LTR you need to put the frequencies in Logical Order.
Also, please update your profile to indicate a location
Bill N1KUG
Old 03-20-2009, 1:09 AM
dave3825's Avatar
I wish they would make that mandatory..
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T Pro 93 tapped Pro 95 tapped
Arc330Pro BcTool Freescan
Old 03-20-2009, 7:10 AM
ecps92's Avatar
Have you been able to ID the LCNs ?? Yet.
Bill N1KUG
