Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Massachusetts Radio Discussion Forum
Massachusetts Radio Discussion Forum Forum for discussing Radio Information in the State of Massachusetts.
Old 09-09-2012, 7:44 AM
ST-Bob's Avatar
Default Massachusetts Buff Agencies restructuring in DB?
The RR listing for Massachusetts Buff Agencies Massachusetts Buff Agencies Scanner Frequencies and Radio Frequency Reference has all their frequencies and repeaters geo-tagged as a large area covering Masachusetts, Rhode Island, southern New Hampshire, parts of Vermont, Maine, New York and most of Connecticut. I'm considering breaking it up into departments with each having its own geographical center and range which would keep location-based scanners from trying to receive these frequencies when out of their intended area of coverage.
I'd like to solicit information from the Massachusetts scanner users on which frequencies should be located in what zones and their areas of intended coverage. For example, right now a scanner with GPS input would still try to receive the Boston area FRS repeater even if traveling in Bridgeport, CT or almost to Albany, NY. This is clearly too broad a range for this little repeater. I'm often plagued by weak, scratchy reception of these systems when I'm clearly not within the intended reception area they cover.
I want to start cleaning this system up. Please respond here or by submitting updates for the system so that I (or another DB Admin) can update the frequencies and geo-tags to more accurately reflect the actual system configuration.
Bob in Worcester - MA db Admin
Bob Peloquin - KB1VUA
Uniden HomePatrol-1, BC100XLT,
R/S PRO-30, Pro-106, Pro-163 (feed provider)
Old 09-09-2012, 10:04 AM
Junior08's Avatar
Bob,
The wiki at Scan New England might be a good reference for splitting these up "regionally" you should be able to use judgement on geo tagging these based on locations posted.
Media and Fire Buff - Scan New England Wiki
Mark,
www.scan-ne.net moderator
Old 09-09-2012, 10:19 AM
zerg901's Avatar
464.90 R seems to have good coverage from Bellingham to Lynn for portables on the street - repeater seems to be in a very high spot in Boston or nearby
464.20 R seems to have good coverage in the Woburn area
463.55 R and 463.85 R might both be located on very high spots in Boston
These 4 seem to have good coverage within 30 mile radius - none seem to reach to Worcester however
Old 10-15-2012, 9:25 AM
ST-Bob's Avatar
OK, I made changes to the Buff Agencies today. If you see any errors in frequencies or locations I chose, please let me know. Massachusetts Buff Agencies Scanner Frequencies and Radio Frequency Reference
Old 10-15-2012, 3:17 PM
RKG's Avatar
RKG RKG is offline
1) You might change "Buff Agencies" to something like "Buff Organizations" or "Buff Groups." "Agency" implies some official authority, while most of these groups are entirely private.
2) 462.725, formerly MRS F1, has been off the air for some time. 463.850 is MRS F1 (and only).
Old 10-16-2012, 7:46 PM
Engineer - SNE DB Admin
Send a message via Yahoo to w1kne
Bob,
There are several tickets for MA RR DB Buff changes/updates , that I have left open for you to tackle when you get a chance.
-- Mike
Mike Fitzpatrick
Southern New England DB Administrator
Broadcast Transmission/RF Engineer
Old 10-20-2012, 4:06 AM
you have 471.4625 listed as providence citywide north, this is the old tac 9 and is not used by providence citywide anymore
Old 10-20-2012, 9:34 AM
ST-Bob's Avatar
Thanks for all your submissions. All handled. Please look them over to see if it meets with your needs. I deleted the old Providence one completely and made some minor changes to the others. Also deleted the area-wide subcategory when I moved FRS-1 into the Boston Metro subcategory.
Bob - KB1VUA
Tags
buff, database, frs, geotag, new england
