KB1UAM - Stop contradicting yourself.
a.) MotorTrbo - Yes can not be Monitored with a Scanner Alone
b.) There is software that in conjunction with a PC and the Scanner will decode the various Digital Audio Formats. Look for the topic here at RR in the threads and the wiki under DSD
Digital Speech Decoder (software package)
Digital Speech Decoder (software package) - The RadioReference Wiki
Depending on the age of your scanner and the various directions this may require openning up your scanner and making a modification, not so with many of the newer scanners. If you are not comfortable with a soldering iron - then don't And don't drop it - the magic Genie will escape
Originally Posted by KB1UAM
mototrbo CANNOT BE MONITORED. if you download the dsd software then you may be able to. you have to connect your scanner to your PC and run the software to listen to it.
