Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 05-15-2008, 12:14 AM
Default MSP system garbled on my Pro 96
I live in Troy (Oakland County) and whenever I listen to the MSP, the transmissions are always pretty garbled and hard to understand. I use a Radio Shack 800 Mhz antenna. Does anyone else notice this problem? Any suggestions?
Old 05-15-2008, 08:45 AM
mikey60's Avatar
In my experience, it depends on the sites you're monitoring. If it's the Detroit or Macomb sub-systems, it's going to be hit or miss. If it's the Romeo, Northville, or Southfield sites (whenever they start using it) then it should com in pretty clearly.
Make sure your DSP firmware is up to date, as this can help as well.
http://www.psredit.com
Old 05-22-2008, 07:21 PM
a29zuk's Avatar
If you are monitoring off any of the simulcast systems the scanner has a problem decoding the signal unless you point a beam at only one tower. The easier solution is to monitor one of the non-simucast sites as Mikey60 mentioned and it will sound a lot better.
Good Luck
Similar Threads
PRO 96 Problem Scanark Radio Shack Scanners 4 01-05-2009 09:45 PM
$4M radio system a 'paperweight' Thunderbolt Community Announcements and News 18 02-22-2008 02:23 PM
Last call for Pomona PD... iepoker Greater Los Angeles & Inland Areas Discussion 103 02-20-2008 03:40 PM
Radio System troubles exkalibur Trunking Forum 33 11-05-2007 08:18 AM
F/S Pro 96 and Pro 2096 JLAB Old Classifieds Archives 0 09-16-2007 08:12 PM
