That talkgroup you mention is on the MPSCS system which isn't EDACS--it's a digital P25 (or Motorola as the scanners call it) system. Also, assuming the database is correct, that talkgroup 7009 is encrypted so there is no way to monitor it on the 2096 or any scanner. BTW, most EDACS systems should be programmed as EDACS WIDE, unless the system type says "EDACS NARROWBAND".
