Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 06-03-2008, 08:12 PM
Question how do i get my scanner to to get my local police
I am new to this I live in ypsilanti Mi. I have a unidenbct8.I have firured how to get to scan all citiys around here. Is it possiable to get it to go from my town and my county police dept,s.I am picking up stuff from all over the place.I do not know how to program this thing but I am willing to pay someone to help me do it. Thank you for any help any one can give my.Dean Thrush. P.S. I have never used one of these before
Old 06-03-2008, 08:41 PM
captclint's Avatar
Originally Posted by mb20fan View Post
I am new to this I live in ypsilanti Mi. I have a unidenbct8.. Is it possiable to get it to go from my town and my county police dept,s
The BCT8 has a function called beartracker, which has 100's of preprogrammed frequencies for all over the country. I suspect that is what you are using now. You can put in only those things which are local, and also your County. Here is a list for Washtenaw County.
At the top, under Washtenaw County Municipalities, are the Washtenaw County frequencies, and half way down, there are 4 local frequencies for Ypsilanti, City of. You can program those in any one of your User Programmable Memories in 5 banks. Just read your manual on how to program frequencies. Of course, there are lots of other frequencies listed under your county, so you can pick an chose what you want to hear. Be sure to turn off the beartracker and just use the scan button.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 06-04-2008, 07:30 AM
Default Thank You
there must be some stuff they do not call out over the scanner I am sitting in my living room and can hear all kinds of police sirens. But nothing over the scanner is this uniden bct 8 a good one or just a cheap one I only paid $200.00 for it
Old 06-04-2008, 08:43 AM
captclint's Avatar
there must be some stuff they do not call out over the scanner.
Yes, that is possible, but not likely with the local, or county. It is more likely with the Michigan Public Safety Communications (MPSCS), which is digital(you can't receive)
No, it is a good radio. Did you program the local and county frequencies yet? The beartracker often does not have every town and city. You need to do the programming. Often, the county dispatches local emergency services, and the local Ypsilanti are more for Tactical communications on scene. The other area of missed communications is due to location and antenna, in that order. If you are using the telescoping antenna in an aluminum sided house, then you may need to move upstairs near a window. Just moving around can have an effect even if you don't have Al siding.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 06-04-2008, 09:58 AM
I have not programed it yet as of this morning there has been a lot of stuff going on all around here that has been interesting.Right now on my screen it is just showing pol--lp and scan keeps scrolling across the screen.On the bottom it showes data with a diagonal line throu it.Since there has been nothing right here in Ypsilanti I would say you are correct that my city is programed in it.As I said I have never used owned one of these before how many channels can you put in one bank.The book is not the greatest also will it scan from one bank to another or do I need to do that myself.
Old 06-04-2008, 10:15 AM
Don't rush to program the conventional frequencies linked above - you need to program the Ann Arbor Washtenaw County trunked system in that list. The police are there.
Old 06-04-2008, 12:02 PM
I am not sure how to program it yet anyway.
Old 06-04-2008, 12:06 PM
I was hoping to find someone close that could give me a hand.The book is not the best to read.
Old 06-04-2008, 12:31 PM
Will Washtenaw Ann Arbor get me the Ypsilanti Police since they are all on the smart net II motorla system.
n2mdk's Avatar
You can download the trial of ARC8 from BuTel http://www.butelsoftware.com/ and use the computer to do the work programming the scanner. It has direct download ability from this sites database, you will need a Premium Subscription to the site to use it. http://www.radioreference.com/apps/subscription/
Attached is a zip file with the programming for your area.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 06-04-2008, 12:48 PM
I am reading this book it is telling me to put in a talk group id.What set of numbers from the link given to me above is the talk group #s
Old 06-04-2008, 01:09 PM
N8IAA's Avatar
If you go to the bottom of the AnnArbor/Washtenaw county trunk system, the 45XXX, 46XXX, and 48XXX numbers for the city PD and Township PD are the TGID's. That is what you enter in the scanlists to monitor your local PD. Ypsilanti Township FD is on the Michigan Public Safety digital P-25 system. The BCT-8 does not do digital.
HTH,
Larry
Old 06-04-2008, 01:21 PM
Thats what I was looking for they have all these headings on the list frequency input license type tone discription mode and tag I am a dummy at this and tring to figure it out man the book kind of sucks it could tell you this stuff. Let me try that and see if I can get it to work. Thank you for your help
Old 06-04-2008, 01:38 PM
OK no I found the list of them on the site are they always 5 digits just wondering.
n2mdk's Avatar
This is the link you want with the trunked system info. http://www.radioreference.com/apps/db/?sid=82
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 06-04-2008, 02:02 PM
N8IAA's Avatar
Not always, my county FD dispatch TGID is 48, the Tac channels are three #'s, the PD and SO are four #'s. I have a feeling that when they migrate to their new P-25, it will be something different. I have them with single and double digit #'s.
Larry
Old 06-04-2008, 04:23 PM
Does anyone own one of these uniden bct8,s when ever I try to enter a Frequency it will not let me enter the last # of it my town is 155-37000 but it will not let me enter the last #
Old 06-04-2008, 04:35 PM
N8IAA's Avatar
Just looked at the manual(I have them downloaded into Adobe), and when you are scanning a bank, press hold/resume, pick the bank channel with the up/down arrows, then enter the frequency 155 (decimal key)37.Press E, frequency is then stored. You don't need to put in all the 0"s.
Larry
Old 06-04-2008, 07:00 PM
How do I know witch set of #,s is the turnking ones that I need. I am sorry I am a dummy at this computers I know.
Old 06-04-2008, 07:17 PM
Is there any one in Mi that I can pay to help me set me up.If I bring them this thing I asked my next door guy that has one and is a ham operator but he only would tell me the 0,s after the decimel point are not used. He hates me I cut down a 2/3rds dead apple tree what a ass-hole he even told he helps fix the local police dept,s raido towers and stuff.Thank you anyone that can help
GO-----WINGS
Similar Threads
Gloucester county pd districts policefreak New Jersey Radio Discussion Forum 8 05-26-2009 05:13 PM
Kansas City Metro Area Scanner Laws kc0vgj Missouri Radio Discussion Forum 7 01-20-2008 06:04 PM
Tennelec police scanner bud229 Scanner Programming Software 10 04-29-2007 10:22 PM
Can't hear Local Police, missing something?? jrc2315 General Scanning Forum 6 05-25-2006 10:26 AM
The Uniden 246T: The next paradigm shift in our hobby... br0adband Uniden Scanners 3 04-29-2005 09:03 PM
