Originally Posted by FPOWLD
I have the following frequencies programmed into my PRO 96 as listed in the RR Data bank but I am not getting anything in the scan mode.
853.2375, 854.3125, 855.3125, 852.2375.
The Mode is set to "MO" . It is in the Open mode (+). When I have it in the scan mode I don't receive anything but in the manual mode I do receive conversation on some frequencies. What am I doing wrong?
I do not have any talk groups programmed in the scanner, I didn't think I needed to in the "open" mode.
Any suggetions would be helpful
Thanks.
If you are hearing voice when in manual mode, then you do not have the scanner set up to decode a motorola system. Make sure that the control channels have a "MO" with them and that you actually tell the scanner it is a MOTOROLA system that you want to monitor. It should work then. You can access the trunk systems by pressing Trunk and Func + Trunk.
Also like Paul said, make sure that you can hear the CC, otherwise you wont be able to monitor it.
Hope that helps
