Originally Posted by vortex360
Thanks for the replies. I have those 4 programmed in perfectly like you list. The strange thing is I am sitting here listening to Van Buren County out of the Jones area. No bars on the signal strength meter are even registering yet it is coming in so crystal clear it is amazing. I also hear Cass County, St Joseph County and Michigan State Police traffic. It is nice to listen to. I heard Sumnerville coming in very faint also. In the meantime I'm amazed to monitor Van Buren County and will keep my ears open for any kind of Berrien County radio traffic. It'd be interesting to see how the 996 performs on the road.
Tee
Tee,
Program the control channels in conventionally and listen to the ones that are red/blue in the database - see if you actually "hear" the control channel data on any of those sites. If not, it may be that you are just too far away - Maybe they are lower power because they have many of them to cover the area and do not need high power. Unfortunately I do not know a thing about this system.
Also, make sure the attenuator on the 996 is turned off globally (and on the systems, if that is an option - i forget).
Also, if you are using the stock antenna that came with the 996, it is my experience as well as many others that the stock antennas on any of the scanners don't perform nearly as well as the Radio Shack 800 Mhz scanner antenna. You might want to consider getting one. Of course, the one I'm referring to is a ducky and you'd need a BNC elbow to connect it up to the 996 or else the antenna would just stick out horizontally. Personally, I think the RS 800 Mhz antenna is well worth its cost. It can be found on the radioshack.com website or in a local radio shack if you are so inclined. Of course, i tell you this only in case you find that the quality of the signal on the Berrien Co sites are not good enough to receive/decode them. And of course, even the RS 800 Mhz may not help a bit, depending on how weak the sigs are.
Anyway, I think that's about all I can offer. You may want to dialog with k8tmk since he may know more about what to expect of signals, etc.
mike
