Originally Posted by hawkeye32
ok just make sure i understand this correctly i enter this number 868.72500 which is the only one for detroit city simucast then hit scan/trunk then just put in the blue ones and thats it?? just hit scan/trunk on the scanner and you can hear both sides of conversation? Or would it be easier to just program in the ID's for what i want to listen too?
Hawkeye...
The 2096 is designed to operate in Control Channel Mode. Simply look at the system that you want to listen to here at RR. Program in the Control Channel(indicated in RED) and the alternate control channels(indicated in BLUE) Tell the scanner that they are Motorola systems and you should be off to the races.
Yes for the City of Detroit, they have a Simulcast system of the MPSCS. There are 10 towers throughout the city. Beyond each tower is only about a mile or mile and a half of signal. The system was designed to keep the signal in the city. This probably has to do with Canada. Many people on these board that live close to Detroit even have a problem monitoring the system.
As far as the Airport Police, right now there are two systems. You want to monitor CA28. This is the Airport Police, Fire and all the crews on the airport. Airport Police are transmitting in the Digital mode while everyone else is analog.
My suggestion if you want to monitor Detroit and Metro Airport is to get a Yagi. Get decent coax(LMR400 as was indicated in an above post) and put your antenna up as high as you can. Make sure if you get a yagi that it is for the portion of the 800mhz band that you want to listen to, otherwise it will do you no good.
Hope that helps you out....any more question feel free to ask away!
