Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 07-04-2008, 12:42 PM
ceranes's Avatar
Question Uniden 246T and Noaa Radio FIPS Codes
I am having trouble getting my 246T scanner to activate with the NOAA Weather Radio FIPS codes programmed in. Does the scanner have to be set to the NOAA radio frequency in order to get the Weather Alerts for the programmed county FIPS codes? Can you scan you memory channels and if there is an alert issued, automatically stop on that frequency and let you hear the broadcasted message?
Old 07-04-2008, 11:28 PM
Yes.
No, not with FIPS codes. You can set it to alert if a warning is issued for anywhere in your area, but that interrupts all comms every few seconds.
Old 07-05-2008, 08:31 PM
ceranes's Avatar
So if I understand you correctly, the scanner has to be locked onto the 162.400 frequency in order to receive any alert information using the programmed FIPS codes? But if I want to scan through the banks of other channels, I need to set it up differently if I want to hear an alert come across the NOAA channel? After a broadcast, does the scanner resume normal scanning operations or do I need manually press the "scan" or "search" buttons?
Old 07-05-2008, 08:52 PM
Yes
Yes - no FIPS codes, it will alert for anything.
Similar Threads
FS: Uniden 246T Tech-Anthony Old Classifieds Archives 3 03-08-2007 04:15 PM
