Status Bits
For my Uniden Scanner, if I set the Status Bit to "ignore", it picks up everything. You should not have to program each of the 16 tgs. Just make sure you have the right setting.
Westland, Wayne, Inkster, Garden City, and Dearborn Heights are on that system. You should hear Westland FD quite a bit, but keep in mind that some other communites dispatch their FD by telephone, so you won't hear as much.
154.37 is still used by some Western Wayne communities, but is no longer used by any of the ones I listed above that moved to the trunked system.
