Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 06-29-2009, 03:22 PM
Flintstone4680's Avatar
Default I need help programming a Pro 106 in Genesee Co
I just bought a new Pro 106 but I can't figure out how to program it. I think I got the frequencies in now how do I put in the talkgroups? The manual and Wiki's are way too complicated. I can't afford to buy any software either. Someone please help. I'm beginning to think 2 months of saving was for nothing.
Pro 106
Pro 96 (semi-retired)
Old 06-29-2009, 05:40 PM
brent30's Avatar
Send a message via Yahoo to brent30
If you have a radioshack near by they will program it for you. Im from Chippewa Co. and i brought mine in told them the counties i wanted programed in to it, they hooked it up to their system, and in an hour I had my scanner programmed. Some people I have talked to said that their local radioshacks were not as helpful. But its worth a try.
RadioShack Pro-197
Uniden BCD396T
Old 06-29-2009, 06:10 PM
You get a free trial run on most of the software programs..give them a try,it is much easier that way.Also check out the software forum,should help too.
Old 06-29-2009, 06:17 PM
Exclamation Programming is Easy!
I had your same problem then i went to psredit.com search for pro-106 and PSR-500. You will get a month trial on the software. You do need the cable from RS but it is worth the money. Play around with it or if you are a premium sub. to RadioRef you can just upload the data from the website and write it to the scanner. I can program one of these in a matter of 30 mins or less now. Questions give me a yell justonymsu@hotmail.com
Justin
Old 06-29-2009, 11:35 PM
Default radio shack pro-106
depending on what type of system it is you may only have to store the frequencies that are designated as control channels,there are primary control channels which are in red and alternate control channels which are in blue,you have to store both primary and alternate control channels,ounce you do this you can start monitering,and you can assign alpha tags as you come across talkgroup ID's,hope this helps.
Old 06-30-2009, 09:37 AM
As he mentioned above, he already has the control channels plugged in. He's looking for help with the talkgroups. In any case, his questions have been answered on the other thread he started.
Old 06-30-2009, 09:09 PM
Actually I still have no idea why i can't get it to work as I'm demonstrating on my other thread. I started this thread in hopes someone local could help me out.
Pro 106
Similar Threads
should i buy a Pro 106 in Genesee County? Flintstone4680 Michigan Radio Discussion Forum 18 04-22-2009 02:18 PM
Programming Pro 106 David3708 Scanner Programming Software 5 04-17-2009 03:57 PM
Thanks Mancow for the Pro 106 u sold me. madr68 For Sale Feedback Forum 0 01-22-2009 02:39 PM
pro 106 STARS programming by hand pogbobo Radio Shack Scanners 10 12-28-2008 06:26 PM
pro 106 programming ? RS2030 Radio Shack Scanners 2 12-23-2008 12:33 PM
