Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 06-30-2009, 09:25 AM
Default Anybody in the Mount Pleasant area?
Just wondering if there is anybody in the Mount Pleasant area that I could sit down with and ask a few questions?
Old 07-01-2009, 07:58 AM
fnnm1062's Avatar
well i dont live in the area, but I am sure if you wanna fire away, I am sure you will get the answers
*Member and Dispatcher for the Fire Notification Network of Michigan paging system - www.fnnm.net
Old 07-01-2009, 02:24 PM
Send a message via Yahoo to djmusic1666
hi weoxstan i live in mount pleasant . and sure you can ask me a few questions. you can post here or
pm me if you like .
PRO 96 /RS84
Old 07-02-2009, 09:11 AM
Thanks for reply's,
Where to start?
I have done some searching and found a freq list for Isabella county and started to input all of the freq's. Last night I was looking over the list and noticed the key's for the columns. Found that some that I had input where digital and since my scanner is analog those are not going to work. However some of them do. I am not sure if they are in the process of switching or the database in wrong, or maybe I am wrong. I noticed the jail and courthouse is digital and on my scanner I do get static transmissions, so I assume that digital is correct. MMR is listed as digital but I can hear that one. If I remember correctly CMU Police is digital but I can hear that as well.
Are there any trunks in the area? What do you recommend for mobile and base antennas? When to use attenuation? Squelch setting? Ahhh Information overload!
Weoxstan
Central Michigan
Pro-164
Old 07-02-2009, 11:33 PM
detroit780's Avatar
Default Isabella
Try this list right here on Radioreference. I only see one digital frequency in it.
Isabella County, Michigan (MI) Scanner Frequencies and Radio Frequency Reference
Les
Thanks for reply's,
Where to start?
Les W8MSP
http://W8MSP.com
http://Michigan-Radio.com
E-Mail W8MSP@W8MSP.com
Old 07-05-2009, 08:33 AM
Thanks for reply's,
Where to start?
hi weoxstan well now let me try to make this easy and simple for you . so your not so overloaded lol:P
plain and smiple pretty much most of mount pleasant is still on the OLD analog system. and does NOT
have any plains on going to the 800 system unless the GOVERMENT PUSHES them to do it . and you
can find the numbers for the OLD analog system in the database here . as they are listed properly .and as
of right now mmr is on a half and half setup meaning in mount pleasant they still use the old analog
numbers . but other areas they cover like saginae they use the 800 system . again just like the rest of
mount pleasant CMU is on the OLD analog system still. and iam not sure if they will go to the 800
system or stay on the OLD analog system alone with mount pleasant due in part that at times mount
pleasant police have CMU police help them out when they need it and are short handed. also too the
trible police use the old analog system . but they do have a talk group on the 800 system but never use it
and for right now the only ones that are on the 800 system is the msp and the drug police.are the ONLY
ONES on the 800system as of right now . but i can tell you this much ictc bussing system by the end of
the fall will be going to the 800 system . with there own talk groups and such . . also too i can tell you that
clare county is on the 800system and you can pick them up too as well . so for now thats where mount
pleasant stands for now . Are there any trunks in the area. to answer that they only trucked system here
in mount pleasant is dte energy. and they are listed in the database here too also.
What do you recommend for mobile . for the mobile end of it . i would recomend useing this antena from
radio shack 800MHz Scanner Antenna - RadioShack.com
as i use it . and it works well . there is a bigger rubber ducky from radio shack i also use . for 20.00$
that they do not have listed on there web site . which also works very well for here . even tho iam
not able to use a base antena where i live at right now . i do recomend this base antena from scanmasters
as its the best one and pretty much everyone i know uses this antena too.
Laird Y8066 Yagi Base Antenna
and as far as the Squelch setting goes . for me i got mine set at the point where it will trip when it picks
up the singles . but will not trip when something random ie trucks cars hit it . and as for the
When to use attenuation? as for that i have not used it . and have not found the need for it myself as of yet.
and iam not sure what scanner you are useing weoxstan as you did not say . but if you are useing the
pro96 digital scanner . i can send you a pm . with the p96 file i use for here on my pro96 scanner . if
you like . that way you can get everything that is covered for here . and you can see what you can pick up
and what you can not pick up. so if you let me know what scanner your useing . and if you like to get
my p96 file from me . just let me know and i,ll post the file for you then . and i hope this is of some help
to you weoxstan
PRO 96 /RS84
Old 07-05-2009, 08:37 PM
Ronaldski's Avatar
Good site the area you want Scanner Home
Old 07-14-2009, 03:10 PM
Thanks djmusic for that info.
Sorry about not having my scanner listed I thought I had it in my signature. I have a RS Pro-164. Not sure if the 96 file will work or not. I am using win97 software right now. I think that will read the 96 file but I am not sure of it.
Weoxstan
Central Michigan
Pro-164
Old 07-14-2009, 03:29 PM
hi weoxstan np at all glad to help. and thats cool as i have done that before too lol. and now i know
what scanner you are useing . even tho i do not have a pro164 scanner . i can tell it should do well with
the analog siginals that mount pleasant. and surounding areas use. but iam sorry to say iam not sure if
it will be able to pick up msp useing that scanner. cuase i dont have one. but if you decied to upgrade
your scanner and get the pro-106 scanner then . you can get all the bells and whistels . and have lots of
interesting litstening then and with the pro-106 haveing privte i-calling. that the msp use . it will make it
even more better . and very enjoyable too. as some of the stuff you can here on the msp and dnr systems
is really a hoot . and iam not sure if the win97 can read the win96 files . as i have not tryed it . so i would
not know if it did or not . but maybe someone eles might know that information.
PRO 96 /RS84
Old 07-16-2009, 08:54 AM
saveourtrainsmichigan's Avatar
Hi
I live in Harrison almost to the Gladwin county line i have a cheap Radioshack antenna about 35 ft off the ground i can pick up all the way to Gratiot county Issabella county comes in perfect.
Here are some of the analog freq #s
Issabella SO 154.875
Issabella county Fire 154.235
I also have the clare county feed up on RR it also covers Issabella Gladwin and Roscommon counties.
Old 07-16-2009, 09:01 AM
Thanks for the info. I am putting up a 20-30ft tower this weekend and was looking at the Procomm Spider antenna, although I have not purchased anything as of yet.
Weoxstan
Central Michigan
Pro-164
Similar Threads
Arizona Frequency Challenge - Part I FLANO Arizona Radio Discussion Forum 41 10-17-2008 09:39 PM
Another big update, 299 new feed links added to scannerfeeds.us jasonpeoria911 Streaming / Broadcasting / Audio Recording 5 06-27-2008 07:10 PM
Mount Pleasant Meadows Freq's? UPMedic Michigan Radio Discussion Forum 1 09-16-2007 06:19 PM
Sticky Thread for MilAir TinEar Maryland Radio Discussion Forum 2734 11-10-2006 06:51 AM
Trunk Lip Mount vs. Hole Mount with the Phantom rmcclellan Antennas and Coax Forum 10 11-25-2005 10:23 PM
