Need help with programming for Washtenaw County
I need some assistance, just got a PSR-400 scanner and programmed in my local trunked system (Washtenaw County). But, after programming it I seem to be receiving Telementry data.
I noted on the scanner that is stopping on control channel 855.1875mhz. When I went back into the database to see what I may have mistakenly included. I noted that within the Washtenaw Government Area. there are two talk-groups 48944 and 48976 which show a discription of Telemetry.
Should I go in and remove those talk-groups which might correct this problem.
My scanner kept me up all night long stopping on that particular area.... (Yes, I know I should have just turned that darn thing off) But, I was just seeing if it would stop... Just programmed it yesterday and wanted to see how it was going to act.
I'm still learning and it seems to be a touch-an-go learning curve.
