Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 10-31-2009, 09:11 PM
Default Setting up Win96 to listen to Sterling Heights PD
I live very close to Sterling Heights (Troy) and would like to listen to their police/fire radio transmissions. I am listening with a Pro 96 and I use Win96/RR to import frequencies and program it.
I am not sure which "Channels" I have to select when I'm using the RR frequency import method. I currently have all of the Sterling Heights Talkgroups (from the MPSCS) but I'm not sure which channels to use since I ONLY want to hear Sterling Heights PD/FD out of this particular scanner. Should I be using Mt. Clemens (868.400 and 868.900) or should I use Macomb County (868.2625 and 868.9875) or neither?
Right now I seem to be hearing a lot of stuff from Roseville/Shelby Township. If anyone can critique my file or offer suggestions I would appreciate it.
Thanks,
Dan
Old 11-01-2009, 10:39 AM
Your pro96 does not do well with the macomb tower (868.9875)its a simulicast system it will be choppy at best .Even my pro 106 does not do well for that tower and I live in Warren .I know someone will tell me about location but thats not the issue at my house .868.900 I beleive is not a control tower any longer .the only 2 control towers in macomb are 868.9875 and 868,1625-romeo '
Old 11-01-2009, 12:52 PM
MPSCS's Avatar
Thanks,
Dan
Dan:
The Mount Clemens tower site is not active. For Macomb County you want to use only the control channel frequency of 868.9875, which is the primary. The alternate is 868.2650, but it is only used if something goes wrong with the primary. Do not program any of the voice frequencies. There are nine towers on the Macomb County Simulcast system, that use these frequencies all at the same time. (Ten towers according to RR's data, but no one can tell me where the tenth one is).
If you set your scanner to scan in "OPEN" mode, you will receive any and all of the talk-groups that are on their system. If you scan in "CLOSED" mode you will hear nothing, unless you program the TG's you want to monitor.
Bill
These are the TG's for Sterling Heights, Michigan:
Old 11-01-2009, 01:49 PM
K8PBX's Avatar
Dan... try the attached file.
Steve
Old 11-01-2009, 02:23 PM
Thanks for the info everyone..I will try your suggestions when I can pull myself away from todays football games.
Old 11-02-2009, 08:35 AM
freqs
I don't have the choppy problem at all on any of the Macomb towerswith my 96. Mine runs smooth as silk on that and St. Clair County. Only place I have a issue is with Warren's system when Im in Warren. But as I understand even their preps and mobiles aren't clear and they often are choppy.
NEWT GINGRICH FOR PRESIDENT IN 2012
Old 11-02-2009, 09:01 AM
Originally Posted by bigbluemsp View Post
freqs
Well I have tried all kinds of settings and just cant receive the macomb co control tower(213), Romeo tower(202) is good but that goes for both 106 and 96.not sure what iam doing wrong ?.Warren for me I get great on my 106 but the 96 like you are saying it motorboats all the time.
Old 11-06-2009, 10:10 PM
K8PBX's Avatar
Originally Posted by freqs View Post
Well I have tried all kinds of settings and just cant receive the macomb co control tower...
Freqs: Do you mostly monitor from a fixed location? If so, consider putting up an outside Yagi antenna pointed at just one of the Macomb 219 simulcast towers. It really did the trick for me.
Steve
Old 11-06-2009, 11:38 PM
I can try it. .most all that i monitor is from home but I have issues with the 106 when Iam mobile as well .thank you.
