Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
  #101 (permalink)
Old 10-27-2013, 7:25 PM
garryd451's Avatar
Location: Pokagon, Michigan, half way between Niles and Dowagiac
Default Database
Berrien County
Niles City Police Department
On the Data Base, 453-9750, 453-9500 and 460-5250 are listed for Niles City Police. I have heard nothing on these for many, many months!
I was told by a Niles City Police, who I asked, that they are on a private radio system, that can only be monitored by their radios.
Garryd451 in
Pokagon
  #102 (permalink)
Old 10-27-2013, 8:29 PM
marcp90's Avatar
Try the MPSCS for Niles. The DB has it listed as 13026. The best tower for Niles would be the Sumnerville tower
  #103 (permalink)
Old 10-28-2013, 12:43 AM
krokus's Avatar
Default Re: We Need Freshly Updated and New Database Information for Michigan (Non MPSCS)
Which may be true, but I am more inclined to think they do not know, or do not want to share the information.
Sent via Tapatalk
  #104 (permalink)
Old 10-28-2013, 6:41 PM
firephotographer50's Avatar
I've noticed that unless you are friends with the officer in question, they will not give you an answer to a question like this. It makes sense and I don't blame them. They don't know who you are or why you want this information and it is a personal safety issue for them.
If you have any radio related questions, the fastest and most accurate responses come from posts on this website. I haven't been led astray yet.
Now back to the main topic .....
firephotographer50
Michigan Fire Photography
http://mifirephoto.smugmug.com/
  #105 (permalink)
Old 02-01-2014, 8:47 AM
Cass county road commission is now operating a TRBO system as opposed to analog. Same frequencies.
  #106 (permalink)
Old 02-03-2014, 1:05 PM
yes in macomb county i cannot pick up any police or sherrif im using uniden bcd396xt scanner does anyone have a guess as to when these frq will be available on rr
  #107 (permalink)
Old 02-03-2014, 4:12 PM
krokus's Avatar
About two weeks ago, maybe longer.
  #108 (permalink)
Old 02-03-2014, 9:20 PM
detroit780's Avatar
Default Macomb
Have you looked here?
Michigan's Public Safety Communications System (MPSCS) Trunking System, Statewide, Multi-State - Scanner Frequencies
2 (2) 019 (13) Macomb County Simulcast Macomb 851.06250 851.13750 851.18750 851.37500 851.42500 851.43750 851.65000 851.76250 851.90000 851.98750 852.38750 852.48750 852.65000 852.67500 852.73750 852.98750 853.26250a 853.98750c
Les
W8MSP Amateur Radio
WQNJ567 GMRS
http://W8MSP.com
E-Mail W8MSP@W8MSP.com
E-Mail detroit780@radioreference.com
  #109 (permalink)
Old 02-03-2014, 9:37 PM
i seen that but im not that savy with the freescan software to program the indivigual frequencies so i need to wait until it comes up on radio ref in the program where it does not say depriciated thanks though
  #110 (permalink)
Old 02-04-2014, 6:51 AM
detroit780's Avatar
Default Macomb
Well if you use RR to program the scanner it should pull in the new data. It's in there now and all the previous frequencies have been removed. So there is no way to program the incorrect frequencies via a RR download through the software.
i seen that but im not that savy with the freescan software to program the indivigual frequencies so i need to wait until it comes up on radio ref in the program where it does not say depreciated thanks though
Les
W8MSP Amateur Radio
WQNJ567 GMRS
http://W8MSP.com
  #111 (permalink)
Old 02-04-2014, 9:50 AM
well i just looked an saint clair shores , sherrif, roseville etc are still saying depreciated i also called able electronics they said it may take rr weeks to update the database of all the ones that switched to MPSCS ALSO i looked at windsor an it said windsor police is unmonitorable it sure seems strange that all of these comunities would go down together this fast jason at able electronics said he has never seen anything like this an he has been referring people to tri- county communications to have there scanners reprogrammed so i called an the lady said it will probably be a couple of weeks before there excepting scanners
  #112 (permalink)
Old 02-04-2014, 9:52 AM
i did try to use the present freq on their that say depreciated an i get nothing
  #113 (permalink)
Old 02-04-2014, 7:13 PM
Listen to what the people here are trying to explain to you. The ONLY reason you would be getting depreciated is because you are trying to look-up their old analog freqs or their old talkgroups. Both St. Clair Shores & Roseville have joined SERESA. Look in the database under MPSCS > Macomb County > SERESA. Eastpointe is also part of this consolidated dispatch center. Macomb County sheriff remains on 50MASH as it always has. In order to receive all these talkgroups you simply need to program the new 85x.xxx listed under the Macomb County Simulcast of the MPSCS.
The reason you cant monitor Windsor PD is because they have been encrypted for the past several years. You can not legally monitor any encrypted communications.
Jason has never seen anything like this because the entire state just re-banded all their MPSCS towers, and he is likely flooded with people saying their scanner isnt working. All that is required is to reprogram the scanner with the new frequencies and it WILL work. I am listening to Macomb County / SERESA right now with no issues.
Visit my West Wayne feed at http://www.radioreference.com/apps/audio/?feedId=12508
  #114 (permalink)
Old 02-04-2014, 7:30 PM
Ronaldski's Avatar
Mid-MI DB Admin
Although all valid questions and answers starting with comment 106, but this forum thread has to do with as the first message says -
We are seeking new and/or updated information for the Michigan database.
What we are asking is that you look at the current Michigan database for your area (and others if you wish), and verify what is there. Also, if you notice anything that is missing please let us know that as well. Newly found frequencies, TGIDs (with the exception of the MPSCS), and systems may be posted in this thread as well.
Should really start a new forum thread imo.
  #115 (permalink)
Old 02-04-2014, 9:16 PM
thanks for putting up with the novice I''ll try to figure it out now with the good info you have provided hope i wasnt to much of a bother im trying to learn
  #116 (permalink)
Old 03-06-2014, 9:08 PM
St. Joseph County road commission is now DMR. Same frequencies.
Tags
sticky
