Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 04-24-2011, 1:21 PM
Default A question about Kent Co. changing radio systems.
A while back there was some talk about Kent Co. and Grand Rapids going to a 800Mhz system either their own or the state system when they can have more talk groups. The question I have is has anyone heard if they are still going to do that or are they going to keep what they got?
Old 04-24-2011, 8:49 PM
Location: Middleville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud Send a message via AIM to Skud Send a message via MSN to Skud
nothing on it yet. Still on hold.
The MPSCS system needs an upgrade before the amount of radios needed, could be added.
When it will happen, you will here it right away on here for sure
I am sure there is no guarantee they will use the state's system. You never know, they could do a Ingham or Allegan county and get their own. Too many variables, will just need to wait and see.
Good reading below:
Kent County going to MPSCS?
Kent county combines dispatch centers
Grand Rapids Approves Dispatch Agreement
PSR-500 | PSR-310
Barry County Scanner http://barrycountyscanner.com
GRPD Scanner http://www.grandrapidspolicescanner.com/
Old 04-24-2011, 8:51 PM
I think the MPSCS upgrade was completed, I know it started a few weeks back.
Old 04-25-2011, 9:27 AM
jack3726's Avatar
Location: Collier-Lee-Charlotte-Sarasota-Manatee County FL
Wonder what the cost analysis would show example: New system install 'VS' jumping on MPSCS.
Old 04-26-2011, 6:59 AM
detroit780's Avatar
Default MPSCS Upgrade
That upgrade happened on 3-23-2011 so it's now able to handle 128,000 radio ID's.
Good reading below:
Les W8MSP Amateur Radio
WQNJ567 GMRS
http://W8MSP.com
E-Mail W8MSP@W8MSP.com
Old 04-26-2011, 1:58 PM
While I'm not going to post a big long thing.. I can tell you that KC Will MOST likely NOT go to the State system. Way to many radios, way to costly, Coverage Sucks, blah blah blah..
Old 12-28-2012, 1:22 PM
I have a friend that stated RS here in kent co told him today kent will be switched all to 800mhz state system in 2013. Wondering if anyone knows more about this.
Old 12-28-2012, 1:29 PM
The rumor isn't true.
And that's all I have to say about that.
Sent from my SCH-I535 using Tapatalk 2
Old 12-29-2012, 9:39 AM
You can say for sure what they will do in 2013, but with the spotty service in the GR area, unless they add a new tower, I don't see them doing that. Since there is no tower in GR, if they are in any building, they most likely will have no service.
I have been watching the County Board of Commissioners meeting notes to see if they have any update, but since early last year I have seen nothing about any type of switch.
PSR-500 | PSR-310
Old 12-29-2012, 9:56 AM
I know this debate has been going in circles for years now... I know they are currently working on rebanding as well as some narrowband stuff and wasn't sure if any of that would effect their plans. Also was wondering if some of the members here had the inside scoop if they were planning on adding all of Kent county on to the state system but it appears its the same debate that comes around once a year of these "rumors".
Old 12-29-2012, 9:57 AM
Ronaldski's Avatar
I'm assuming also they and prolly others will wait for the rebanding of the radios to be done or when the the new frequencies to be turned on at this point.
I know Bay county waited for their radios to be rebanded till they went digital on the 12th. Meaning the radios have the capability to use the new frequencies but are still using the non rebabnded frequencies.
Old 12-29-2012, 10:22 AM
No. They are not moving to MPSCS. It has nothing to do with rebanding or narrow banding or anything. It is not like what Bay County is doing.
To repeat, they are NOT moving.
Old 12-29-2012, 11:06 AM
Ronaldski's Avatar
I know they are not moving! I repeat I gave bay county as an example ONLY !
I used the word 'assuming' as opposed to 'i know' btw you saw there the two threads pertaining to the same similar subject.
Old 12-29-2012, 2:16 PM
That's my point. Your assumption has nothing to do with what is actually happening in the real world. They aren't waiting for anything.
Old 12-29-2012, 2:30 PM
Listen folks.. As one of the 9 800MHZ radio users from KCSD. I'll tell you right now I'll be sure to share with you when and if they make the decision to change to the 800MHZ system.
Why is Kent County not going to switch any time soon?
#1) Coverage - My portable gets about 75% coverage in Kent County. I'm sure someone will say I'm wrong but I've been all over the county and I can tell you what it does and doesn't do.
#2) Cost - The fact is radios cost between 2-5K each. I'd guess 100 radios per department and minimum. Give or take a few. Plus the yearly user fee @ 200 per radio
#3) They just spent money on becoming narrow band compliant.
Every 6 months this rumor pop's up. It pop's up to get everyone all worked up and then one of us in the know pop's in and ruins it.
Just smile and enjoy.. If your wondering about buying an 800mhz scanner to monitor stuff in KC do it. You'll enjoy it. Lots of traffic, just not from non state agencies in Kent County.
Old 12-29-2012, 3:54 PM
So you're saying... there's a chance?
Old 12-30-2012, 10:38 AM
drdispatch's Avatar
That depends; Do you consider buying 1 Lotto ticket when the jackpot gets to 30 million ''a chance''?
Scanner geek since 1974
PRO-2004/PRO-92/PRO-96/HTX-202/Motorola MCC-5500
"My Daddy sends smoke signals to Indians who arrest trolls & squirt water on dragons. What does your Daddy do?"
Old 12-30-2012, 5:57 PM
Better bet - in 6 months someone will start this rumor again. And those in the know will deny it. And then others will offer assumptions that have no basis. And we will roll the ball again!
Old 12-30-2012, 8:48 PM
Cost, they didn't spend that much since they have a surcharge all cell phones that have a phone number in the kent county area.
PSR-500 | PSR-310
Old 12-30-2012, 8:59 PM
Thunderbolt's Avatar
Forums Moderator
I do know that when the rebanding project is finished, there will be a lot of leftover Quantar transmitters that are planned for new sites, or expansion of existing ones. Grand Rapids is one location that will receive a new site to improve reception in Kent County. Unknown at this time where the transmitter site will be located at, but current thinking is that it will be on top of a tall building in the downtown area.
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
