Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum - Forum for discussing Radio Information in the State of Michigan.
Old 08-12-2011, 9:40 AM
tcg tcg is offline
Default Programing St Clair County
Hi,
I picked up a used Uniden BC796D I have an ST2 antenna mounted outside about 37' in the air with a clear view. With this scanner I have no problem picking up analog stuff, specifically the marine band stuff (154.000 161.000) for about a 30+ mile radius.
I used ACR250 to program the scanner. What I end up with is in the first bank first channel the primary control frequency of 868.63750 and in the first bank second channel the alternate frequency of 868.45000.
I also programmed several talkgroups. Pretty much the same ones as this feed.
St. Clair County Law Enforcement Live Scanner Audio Feed
My goal is to add the 2 marine divisions that cover Lake St. Clair (St Clair and Macomb) to my live feed.
I am not receiving anything close to what the live feed above is receiving. I've spent several days reading and trying different things. I am at a loss.
ACR250 sets up the control channels as Type2/P25 800. Over in this topic I was told that was incorrect.
http://forums.radioreference.com/uni...ml#post1591159
The first question is what type of system is MPSCS and how should I set it up in my scanner?
Thanks.
Old 08-12-2011, 11:12 AM
OsloViking1975's Avatar
Originally Posted by tcg View Post
Hi,
Thanks.
MPSCS is a APCO-25 Common Air Interface Exclusive. All digital. So you would need to set your scanner to P25 if your scanner has an option for that. Put in the two control channels as mentioned. Sorry I am not familiar with Bearcat Scanners.
868.63750 868.4500
Then just put in your talk groups you want.
Your scanner will not pickup the 700MGz but I think you will be fine for now.
I'm to sure if you need the latest firmware update or not but here is a link.
http://info.uniden.com/twiki/bin/vie...FirmwareUpdate
Make sure your APCO 25 card is installed.
Baker College Major:Criminal Justice
Monitoring Macomb,St.Clair, Wayne, and G.P.I.S.
"Dedication lies in the hands of those who are dedicated". 9-1-1 Certified hours completed.
Old 08-13-2011, 12:38 PM
MICOM's Avatar
Default Info
Please check your PM's.
