Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 12-25-2012, 7:21 PM
Default Kent County p25?
I'm hearing p25 audio crisp and clear on my pro 106 in kent county. Uhh nothing on radio reference about it? Here are the freqs:
866.325
866.4375
866.8625
867.3625
867.9625
868.325.
Also, when the 106 was bought, the guy at radioshack told me that kent county switched to the new trunked system. If this is true, this should be added to the MPSCS.
Old 12-25-2012, 7:26 PM
Those freqs are all listed in MPSCS. Not sure what you are looking for?
The sales rep lied.
Old 12-25-2012, 7:39 PM
You did not look at a part of the message. It said "recieving p25 audio crisp and clear in KENT COUNTY."
Old 12-25-2012, 8:02 PM
I see that. Those freqs are from the Barry Co tower, which you should hear just fine in KENT and they are listed in the RRDB.
Old 12-26-2012, 9:13 AM
Kent County Sherrif and Fire are both still using their vhf systems and the rrdb data is up to date. Your friend at Radio Shack is mistaken
Sent from my Nexus 10 using Tapatalk 2
My Feed: Kent County North Sheriff and Fire
My Scanners: GRE PSR-800 | PRO-404
Old 12-26-2012, 12:40 PM
maybe your right. But I heard them say "grand rapids" and " 13 mile rd", Which is in kent county. I think the person did lie.
Old 12-26-2012, 12:43 PM
If you look in the RRDB under MPSCS, you'll see that MDOT operates in Kent Co, the drug team, and MSP.
Old 12-26-2012, 12:50 PM
I figured it out. It turned out it was cedar springs and cannonsburg that uses the p25 I was talking about.
Old 12-26-2012, 3:31 PM
Cedar Springs is dispatched by Kent County on the VHF system and Cannonsburg is patrolled by the Sheriff.
I think what you are hearing is the MPSCS as Rdale mentioned in post #4. MPSCS will broadcast to any radio listening in on it for the talkgroup it is subscribed to, I think what you heard was a unit that was on a talkgroup that covers that part of Kent county but the radio was currently locked onto that tower in Barry County.
Did you log the TGID and/or RID of the broadcast?
Old 12-27-2012, 1:28 AM
Location: Middleville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud Send a message via AIM to Skud Send a message via MSN to Skud
I have never been able to get the Nashville tower in GR. Sometimes in the right areas I can get the Plainwell tower but again almost no where except on the expressways,
I wounder if edriaw1 does not have it set to P25 and just set to scan all those as a conv so it is just picking up voice traffic when someone talks on any tower close like the Cedar Springs and Cannonsburg towers that I see some of those freqs are listed on.
PSR-500 | PSR-310
Barry County Scanner http://barrycountyscanner.com
GRPD Scanner http://www.grandrapidspolicescanner.com/
Old 12-27-2012, 1:07 PM
I do mostly have conventional channels because there's no major trunked systems in the county. I now have those p25 freqs in search. And in search it automatically found out it was p25 audio and displayed the NAC when it landed on those freqs. So maybe you guys are right.
Old 12-29-2012, 8:35 AM
that those P25's out. They are for a trunk system and you are going to miss most the conversation because it will keep changing channels. If you want to liten you will need to setup new trunk systems for cedar springs and the cannonsburg towers.
PSR-500 | PSR-310
Old 12-29-2012, 9:58 AM
Ronaldski's Avatar
Why do we have two threads on the same subject? Can we combine the two ? Any admins to do so?
Old 12-29-2012, 10:23 AM
I only see one thread about his programming issues. Link to the other?
Old 12-29-2012, 5:30 PM
oh so now my thread has to be about programming issues. UGH I cannot make any of my threads make sense.
Old 12-29-2012, 8:54 PM
Correct. As we noted above, those are MPSCS towers. You had them in conventional mode and those are trunked frequencies.
